-   Power Supplies (https://www.hardwarecanucks.com/forum/power-supplies/)
-   -   How much wattage? (https://www.hardwarecanucks.com/forum/power-supplies/42786-how-much-wattage.html)
baligena April 24, 2011 06:29 AM
How much wattage?
How do I determine the amount of wattage my computer will need? What do I look at? What do I pay attention to?
_dangtx_ April 24, 2011 06:36 AM
look up a review of your intended cpu...look for idle/load system power draw
then look up here for the gpu : AMD Radeon HD 6670 1 GB Review - Page 20/26 | techPowerUp
and then add more watts if youve got something special going on,like a bizillion fans and so on.
KaptCrunch April 24, 2011 06:47 AM
or use a tool from asus power calculator
baligena April 25, 2011 06:42 PM
Asus power supply
asus power supply was very useful thank you.
thank you
spikexp April 26, 2011 07:37 AM
All these online calculator are not so precise.
The asus power calculator ask for 550w min for my config.
Antec Power Supply Calculator
Give me 376w min, way better already.
KaptCrunch May 3, 2011 10:22 AM
antec gives no head room for future add on's
enaberif May 3, 2011 11:00 AM
Calculators suck and should NEVER be used.
Give us a system spec breakdown of what you have and then go from there.
Galcobar May 3, 2011 04:11 PM
Because what you'd be doing in your head is so completely different from what a calculator would do?
Question the accuracy of specific calculators, I understand. Rejecting the entire concept seems an over-reaction.
enaberif May 3, 2011 04:12 PM
Calculators have a tendency to either gross underestimate or gross overestimate
_dangtx_ May 3, 2011 04:18 PM
reason for which you invest 20 dollars in a power meter and find out for real :)
