<~----> Good PSU? - Hardware Canucks
Old April 20, 2011, 04:56 PM
Default Good PSU?
I'm wondering if an antec bp550 would be suitable for gaming on my PC and I'm also looking into folding.
My specs are:
Intel core i5-750
Radeon 5830
8gb samsung DDR3 RAM 4x2GB
1.5TB hard drive
Optical drive
Possibly adding an Asus Xonar in later.
Will it be enough?
Old April 20, 2011, 05:05 PM
sure,its not a bad unit,but you could do better :)
Old April 20, 2011, 05:13 PM
^^^^^+1
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old April 20, 2011, 08:54 PM
For that build you can get almost any 500W PSU on the market. Stick to brands that are known for good PSU and you'll be in good hands. My choices would be Seasonic, Silverstone or Corsair.
Old April 20, 2011, 10:50 PM
Thanks just wanted to be sure. Main issue was price and I couldn't find much around that price, I also heard antec is a fairly reliable brand. Out of curiosity are there any others around the same price you would also consider before this one? What about the antec high Current gamer 520w? It was similar in price (only a few dollars cheaper) but no modular cables.
Old April 20, 2011, 10:53 PM
look for a small vattage seasonic built one,400 of real watts :)
Old April 20, 2011, 11:09 PM
Would it also be able to handle ocing GPU and CPU? I'll probably be maxing the gpu oc if possible and I might look into minor oc of the CPU.
Old April 20, 2011, 11:14 PM
burebista's Avatar
Antec BP550 Plus is a Delta but TBH I'd prefer the Seasonic from Antec HCG520. Or the Seasonic from Corsair TX650 V2.
Here both HCG and TX are roughly at the same price with BP550.
If it ain't broke... fix it until it is.
Old April 20, 2011, 11:48 PM
That corsair is a tad expensive for my budget so I probably wouldn't get that one. Is there a particular reason why you 'would prefer the hgc520 over the bp550?
I wish power supplies were exactly what they are advertised as instead of being so confusing because of overrating and whatever... It would make choosing one far easier.
Old April 21, 2011, 12:01 AM
Not a major problem if you want to get the Antec BP550 and a 500W can pretty much handle any CPU and mid range GPU with overclock no problem. You could also try looking for the Silverstone Strider Essentials 500W as well.
Is my PSU good enough? Kam Power Supplies 6 July 17, 2010 09:09 AM
Is my PSU good enough? hen555 New Builds 7 January 14, 2010 05:24 PM
Good psu? NexRedshirt Power Supplies 10 April 7, 2009 09:57 PM
Is my PSU good enough? SniperClops Troubleshooting 3 October 8, 2007 08:07 PM
good psu ? Jim Power Supplies 3 August 26, 2007 10:08 PM
