Old April 7, 2011, 11:52 AM
werent those seasonic built? look up the ul number on the side.
Old April 7, 2011, 12:37 PM
Yes they are, the TP3 and the TP that the OP has are different platforms though, the TP3 was only supposed to be a 500W unit and the True Power New (the one the OP has) can actually deliver a little more than its labeled wattage rather safely, but after that the overload protections will kick in.
If the OP doesn't fold with CPU+2GPU he is definitely fine. The unit will shut off properly if he doesn't have enough power.
Old April 7, 2011, 04:49 PM
Yeah, TP is a Seasonic rebrand. I think right now, with the opinions suggested here, this TP will handle my power usage for the time being.
I guess I'll be upgrading to AX850 or such in the future as I will be upgrading my GPU as well as for peace of mind.
Old April 7, 2011, 05:00 PM
peace of mind would be getting one of those units and check how much youre pulling :)
i always hook one up for a new rig. never have surprises this way ;)
Old April 7, 2011, 05:26 PM
Soultribunal's Avatar
You should be okay, around 480-520W roughly.
RIght now APC says my Rig pulls 432. Its pretty close to where you are at.
Intel i7 930
EVGA GTX460 SC x 2
6GB G.Skill
3 200MM Big Boy Fans
3 120mm Fans
Corsair H50
OCZ Ram Cooler
3 x 640 Blacks
1 x Force 100
You should be okay, so long as that Seasonic is sound.
Mine is the HX650.
ST
www.realhardwarereviews.com
Old April 8, 2011, 12:01 PM
Yeah, that's not a bad idea I think and should be useful in the future. Next time I'm at Canadian tire, will definitely look at one of these.
Old April 8, 2011, 12:06 PM
or
Newegg.ca - P3 Kill A Watt Electricity Load Meter and Monitor
but you can find them cheaper, got mine for around 20 shipped i think, from the bay if memory serves right.
Old April 9, 2011, 01:30 PM
how old is your psu ? you should also think about the efficiency of your psu, which will decrease gradually ..upgrade your psu mate.
  #19 (permalink)
Old April 9, 2011, 10:48 PM
LionRed's Avatar
I was running GTX 480's sli'd, with an overclock of 4.2 or 4.0Ghz (920) on a Corsair 750HX (I think it was HX). PS seemed to handle it very well....but I wasn't crazy about using it..however my 1500W was out for RMA.
Personal preference is to overspec on the PS...peace of mind. This is just my personal preference....some people don't mind and are perfectly OK running a PS at 80% draw or so. I just didn't or don't like the idea if my PS goes up in smoke...it will or could take a lot more with it, and I don't even want to begin getting into the trouble shooting parts stuff...stress and money of replacing the rig I have.
They say you can tell how rich a man's life has been, by how many dogs he has had in it.
RIP Kiwi - Oct 19th/05 - April 18th/11, you will always be our puppy!
Should I upgrade my PSU now? wonton1017 Power Supplies 6 December 5, 2010 07:57 AM
VGA upgrade from GTX 260 first, or CPU+mobo upgrade first? panzerfan Video Cards 9 April 6, 2010 08:25 PM
Upgrade (gfx, psu, cooler) fiddy New Builds 5 November 2, 2008 11:14 AM
PSU upgrade Para_Franck Power Supplies 5 May 13, 2008 08:46 PM
need PSU suggestions, current PSU isnt cutting it Rains Power Supplies 13 December 11, 2007 08:53 AM
