-   -   Antec PSU size fit (http://www.hardwarecanucks.com/forum/power-supplies/41212-antec-psu-size-fit.html)
sankukai February 28, 2011 05:05 PM
Antec PSU size fit
Hi there guys:
I am seriously considering spending some of my hard earned cash to purchase an Antec Quatro TPQ-850w PSU. I was told by one of the sales people at the store I plan to order it from (I live in Nicaragua, Central America)that the unit is pretty large and won't fit inside my current Micro-ATX case. The thing is, I don't want to shell out another wad of cash to buy a larger, more expensive case unless I really need to. Is it true that this psu will not fit inside a regular micro-atx case? or this sales guy just jerking my chain so I buy a new, 70 plus-dollar mid-tower case from his store?
Any thoughts would be appreciated
Stock February 28, 2011 05:27 PM
What case are you using right now? The 850W Quatro is a standard sized (ATX) power supply. A quick google shows that its dimensions are 8cm (L), 15cm (W) and 9cm (D). It should fit as long as you aren't using something like a slim-mATX case with proprietary psu's.
_dangtx_ February 28, 2011 05:42 PM
Antec TruePower Quattro (TPQ-850) 850W Review
good unit, but not exactly micro psu size.
http://www.antec.com/Believe_it/product.php?id=NTg=
Dimensions:
- 3.4" (H) x 5.9" (W) x 7.1" (D)
- 8.6cm (H) x 15cm (W) x 18cm (D) Net weight:
- 5.75lbs / 2.6kg
sankukai February 28, 2011 06:10 PM
well...I couldn't really tell you the case's brand because I really don't know where it's at. But it's the case that came when I bought with my old Core2Duo rig. It fits the Asrock Micro-ATX motherboards I have had including the G31M-S that I have bought last year, without any trouble at all.
Mu current Kmex 650w switching power supply fits in without any trouble too
I don't know if that is enough info for anybody else to add a suggestion though:sad:
_dangtx_ February 28, 2011 06:18 PM
you can always take a picture.
some cases have liek a bar or like a 'lip' that will make it either hard or impossible to install the
psu without taking the mobo out first
Stock February 28, 2011 08:18 PM
Use a ruler and measure your case... Dangtx and I just gave you some figures.
And wow! I must be really off on the size of the unit...I pulled those numbers here. Probably best to go with Antec's website.
_dangtx_ February 28, 2011 08:45 PM
yeah, its one of the bigger heavier units :p
krajee March 1, 2011 12:39 AM
I would actually suggest measuring the current power supply and comparing it to the dimensions of the TPQ850 rather than measuring the case.
Dr_BenD_over March 1, 2011 12:34 PM
The ATX standard (2.2) is only 14cm (D) so it may indeed be too deep for the case.
mo' power March 2, 2011 11:36 PM
If your psu is the Kmex PG-650W, you should be ok. From what I can tell, the TPQ 850 has the same height and width. It's 4cm longer though. Both psu's are ATX 2.2.
