Old January 17, 2008, 01:57 PM
reaverclan's Avatar
well i hope nvidia fixes it cause that sucks mine works though:)
Old January 17, 2008, 02:32 PM
random_2's Avatar
Post
enaberif I know I was thinking the same thing....Why would I need the 4 pin molex connected also?....But when you have issues, a guy will ty almost anything
SKYMTL Thanks, although I haven't posted here before, I know you've done more than your fair share of PSU reviews. I appreciate your opinion, and the link.
I have seen this in a couple of forums when "googled" , so I think I'll have to RMA this puppy. SKYMTL ..ANy Recomendations for a reasonably priced PSU
with longer cables for the Coolermaster CM690 that will work with the 8800GT?
Appreciate all your help and input guys. Nice to know there's brighter people out there willing to help.
Randy
Old January 17, 2008, 02:36 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
I can't tell you what will and won't work with the 8800GT. The issue seems to be pretty random but I have yet to experience any problems with the Silverstone units. Maybe have a look for the OP650 or DA650...
Old January 17, 2008, 03:25 PM
random_2's Avatar
Thanks SKYMTL....will do. Again, I really appreciate all your help.
Old January 17, 2008, 07:27 PM
Originally Posted by reaverclan View Post
that should be plenty to run the 8800gt although 500w is the minimum to run a 8800gt.
didnt noe that .. been running an antec trupower 430w . havent been having any issues like that message tho .
i was ready to go get a 550w when building the system when my neighbour-turned-pro-systems-builder advised me that 430w was more than enuf even with an 8800gt, saying the trupower was very power-efficient .. do i need 2 get 550w now lol ?
Old January 17, 2008, 08:51 PM
I have the same board but a different video card. However, I have the benefit of a power meter with the Zalman ZM-MFC2 Controller. With all my system running and running the stress test using Everest, I am only drawing maximum 118W. At idle, the power draw sits around 105 -108Watts. Even with your rig, you should not be drawing more than 50Watts more than mine. Its got to be something else.
ASUS Z97-DELUXE; INTEL i7 4790K ; NOCTUA NH-U12P; PNYGeForce GTX 760 OCX ; LIAN-LI PC-V1020 CASE; SEASONIC PLATINUM 860; WINDOWS 10 PRO 64-BIT.
Old January 17, 2008, 08:54 PM
Prof. Dr. Silver's Avatar
118W??? Are you sure that is correct? Perhaps that is just the videocard usage...It is a tad too little for that system your running! You should run at least 300W!!
Hardcore Folding at it's BEST! HWC - TPU.... There can be only one team in front! TPU, can you smell our *sses already?
Old January 17, 2008, 09:17 PM
MpG's Avatar
MpG MpG is offline
Check Malam's sig. A dual-core at only 2.3 Ghz (probably no voltage increase), a P35 chipset, and a 2600-series card? It's the idle power draw that seems a little high, I'd say.
Harlequin2134: You can run a rig with a GT on a 430W PSU. The 500 is certainly a good idea, but you've still got plenty of headroom, especially with a dual-core processor.
  #19 (permalink)
Old January 17, 2008, 09:58 PM
As I am typing this message, the power meter is sitting at 108Watts (CPU Core @ 1.31V and DIMM @2.01V). In addition to the equipment listed below, I also have 2 x 500G WD SATA drives, a Plextor 712A DVD/RW drive and an LG DVD/RW Lightscribe drive. 4 case fans and my cpu is cooled by the stock intel cpu fan and 2 x1024 OCZ Ripper PC6400. It will be interesting to see who else has a power meter and what they are reading.
  #20 (permalink)
Old January 19, 2008, 11:30 PM
I was under the impression that it all comes down to the amps on the 12 volt rails? my "crappy" 375 watt dell powersupply is rated @ two +12V rails 18amps each... thats more than some 600 watters. It has no problem powering my 8800gt aplha dog? Wattage isn't everything, look at what the 12 V rails are rated at and see if it meets the 8800gt specs.
Corsair Introduces New 450W and 550W Power Supply Units Babrbarossa Press Releases & Tech News 1 August 1, 2007 12:34 PM
