Old February 27, 2011, 12:00 PM
Cowboy's Avatar
Default Is 300w enough for my setup? Should I be worried?
Running a m-ITX rig with a mildly OC'ed i3-530 and a GTX 560Ti from ASUS ("Superclocked") on a 300w Silverstone SFX PSU (80+ bronze certified)
Is it enough? Do I have some more room for OC?
Old February 27, 2011, 12:05 PM
You probably don't "need" one, but your system can probably pull the full 300W from the unit under extreme loads. If you fold with both CPU/GPU or find yourself heavily stressing your entire system a lot, I would look into a unit with more rated wattage.
Just look at the TDP's of your GPU and CPU. 170W+72W=242W, add some for the rest of the components and a little more for an OC. (itx motherboards usually don't pull much though)
Old February 27, 2011, 12:06 PM
no more than 150 watts for the system alone, save you went mental on the juice.
could be as low as 100-125 though.
and for the 560, regular 3d gaming,.,,maybe 165 watts?
HIS Radeon HD 6850 IceQ X Turbo 1 GB Review - Page 21/27 | techPowerUp
so depending on your psu, if it can hold 300 watts day and night yes if not maybe get something beefier.
Arinoth's Avatar
Personally i would be, you're driving a lower high end card which is already overclocked on a power supply which is also having to supply power to an overclock processor. I'd bump up to at least 450W otherwise i could see that psu biting the dust if the entire system is ever loaded for a long duration.
TDP doesnt take into consider overclocking, i wouldnt be surprised if the GPU is pulling 200W+ overclocked on full load and the processor pushing near 100W again fully loaded and overclocked.
Also folks, dont forget most PSUs are only 80% efficient near full load, so essentially his power supply would actually pulling an extra 20% most likely with that set up driving the power supply HARD.
Old February 27, 2011, 12:08 PM
Cowboy's Avatar
its a $70 purchase, so I better be damn sure I'll need it...
Old February 27, 2011, 12:11 PM
I think you're kind of pushing it though I don't know how many peripherals you have tacked on. At load your system is already around 250-275W, and with 80% efficiency it's closer to 250W if anything. An i7-920 system paired with the 560ti at load uses just over 300W. You could probably do a small OC on the CPU but the tradeoff for heat/noise from the power supply is up to you.
Old February 27, 2011, 12:12 PM
why dont you invest in a 10-20 dollar kill a watt? will save you white hairs in the long run
how? what i do is i plug it in, and power it up. i look at idle juice being pulled at the wall of course.
id the idle numbers are higher than what id expect, i wont load either cpu/gpu and shut it down. if they look
normal, then i start up prime, look at the numbers then try 3dmark.
say your psu can do 300 watts on the 12v line..mkay?
and prime+3dmark shows no more than 300 at the wall? youre cool. given its a good psu.
FSP300-60GHS Power Supply Review | Hardware Secrets
You have a pretty solid unit, as long as you're not CPU+GPU folding or doing something else that stresses your system beyond heavy gaming, you'll be fine.
Old February 27, 2011, 12:13 PM
Cowboy's Avatar
peripherals include a mouse + keyboard, charger for iphone + Kindle, and USB DVD drive, occasionally a printer too... and I have 2 USB ports leftover.
Running an SSD and a 7200rpm 3.5" drive.. along with 1 fan and a corsair H50... 2 sticks of ram... nothing else I think..
Old February 27, 2011, 12:15 PM
Obviously your PSU will run your setup, but you are at the limit. Your running a nice video card and don't think its worth the risk of killing it. Grab a quality PSU of 450w minimum. I would go around the 500w mark.
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Worried I have have damaged by board ToXic Troubleshooting 4 December 4, 2010 04:31 AM
300w psu enough? heatchem New Builds 11 October 26, 2010 08:10 PM
Silverstone SUGO 05 - 300W enough for the following? xghostz Power Supplies 9 July 4, 2010 07:33 PM
HD 4670 on Dell 300w psu? Bond007 Video Cards 13 March 15, 2010 05:55 PM
Is anyone worried about the psyko 5.1? Technokat Audio 3 July 22, 2009 02:35 PM
