Old February 16, 2011, 11:27 AM
Default PSU WATTAGE !!!!!!.... plz respond ><
I'm planning on building an i7 sandy bridge 2600k(overclocking 4.2 ghz+) system with a single gpu amd 6950. One ocz 64gb/60gb ssd, one 7200 1TB HHD, two DDR3 1600mhz 2 gb ram, cooler master 212 plus cpu cooler, and a cd drive.
How much wattage would it require and which psu should i get if my budget is only around 70 dollar?
i know there is psu calculator out there but sadly the dont have the new sandy bridge as an option when choosing cpu... so i need suggestions from experienced ppl thx :)
Old February 16, 2011, 11:30 AM
600 W would be fine for that.
Old February 16, 2011, 11:32 AM
3.0charlie's Avatar
70$. Such a nice system, and you skimp on the most important component. I would not.
I concur, 600w is plentiful.
Hydro-Quebec is salivating...
Old February 16, 2011, 11:34 AM
I agree. I'd say get the corsair cx600 - good psu for the cost. around $90 with taxes if I remember correctly.
Old February 16, 2011, 11:38 AM
Slaughter's Avatar
You could always pick up a Corsair TX650 used as they are running within your budget if used it a route you'd be willing to go.
Old February 16, 2011, 11:45 AM
Default thx for the reminder
haha yea i was thinking abt raising my budget too b/c i do understand other then cpu and mobo psu comes third >< maybe i should consider the corsair 650w
Old February 16, 2011, 11:48 AM
Soultribunal's Avatar
Best advice out there right now mate.
Don't make the PSU the cheapest component in your system.
Silver Stone has the Strider Plus units going fairly well priced, as well as the mentioned Corsair ones. They are solid Power Supplies.
ST
www.realhardwarereviews.com
Old February 16, 2011, 11:52 AM
earthwatts 500? :)
dont think youll be pulling more than 250-300 watts on the 12v.
Old February 16, 2011, 08:32 PM
I can concur with the estimate of 200-300W. My rig with an i5 2500k overclocked to 4.2 GHz (CPU folding, GPU idle) only pulls 200W FROM THE WALL so what it's getting from the 12V is less.
The following Seasonic should do the trick if all the wires are long enough:
NCIX.com - Buy Seasonic S12II 520W EPS12V 20/24PIN ATX Power Supply Active PFC 80+ Bronze 6+8PIN PCI-E W/ 120MM Fan - S12II 520 In Canada. ($65 before taxes with NCIX's sale)
Note that you'll limit yourself to one high-end GPU with that power supply, but that's about as much as you can get for a power supply that's around 20% of the price of your CPU...
Last edited by frontier204; February 16, 2011 at 08:33 PM. Reason: clarification on load
Old February 17, 2011, 12:41 PM
I have seen many different psu wattage calculators online like :
eXtreme Power Supply Calculator
Does anyone else have a favorite they like to use?
What PSU wattage do I need? avrionis Power Supplies 8 December 30, 2010 06:33 AM
messenger live failed to respond CTA O/S's, Drivers & General Software 4 July 31, 2010 02:22 PM
Thermaltake Launches Next Generation Toughpower XT PSU Series with Enhanced Wattage FiXT Press Releases & Tech News 4 February 5, 2010 07:02 PM
Gskill can i rma it? PLEASE RESPOND asap:) WolfBane RAM 18 August 21, 2009 05:28 PM
PSU Help Plz derrXIII Power Supplies 5 September 16, 2008 08:27 AM
