Old January 11, 2008, 01:06 PM
Prof. Dr. Silver's Avatar
Default PSU readings
Yo Yo Yo!
Here are the readings I took today from a new PSU called Zumax X4 750W.
They seem a little high to me but maybe someone can comment? Measurements were taken with a Sperry DM 350A Multimeter.
The first set of numbers is idling and the second set of readings are done under heavy load...3DM06/Memtest/Prime95/Defragmenting HDD's...LOL
FDD : 5.12V / 5.17V
FAN : 5.79V / 5.79V
PCI-E : 12.61V / 12.57V
Sata : 5.14V / 5.14V
CPU-4: 12.61V / 12.58V
3.3V : 3.46V / 3.46V
Hardcore Folding at it's BEST! HWC - TPU.... There can be only one team in front! TPU, can you smell our *sses already?
Old January 11, 2008, 01:11 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
How long has it been since the DMM was calibrated? Have you confirmed these readings with a bifferent DMM?
Old January 11, 2008, 01:39 PM
That DMM is brand new! The BIOS says different things though....remember the Sensor issue I was talking about?? Here's some pics.
See the 4.08V rating on the CPU? Weird huh?
Old January 11, 2008, 02:00 PM
SKYMTL's Avatar
Recheck with another DMM and don't listen to what the BIOS is telling you since yours seems to be posessed or something.....
There are a few other things which reviewers in general rarely take into account when testing PSUs:
- Try not to take voltage readings from an unused connector.
- Load your test PSU properly (a run-though of 3DMark06 is NOT "load")
- A combination of 3DMark + Orthos + Memtest makes for mutually exclusive load conditions so you will not be putting your PSU under any more load than if you were straight-out running 3DMark
If those are the correct voltages, then that PSU is a massive failure. Period.
Confusing temperature readings magictorch CPU's and Motherboards 7 November 30, 2007 05:47 PM
Odd Sensor readings. Dethredic Overclocking, Tweaking and Benchmarking 15 October 29, 2007 08:08 PM
Way too many temperature readings! Mibs Water Cooling 2 August 4, 2007 12:00 PM
Wierd CPUZ readings... Babrbarossa Troubleshooting 1 June 5, 2007 02:35 AM
