Old January 24, 2011, 08:50 PM
Default Measuring power consumption: UPS underestimating?
Hi all,
I have a APC Back-UPS ES 750 uninterruptable power supply that I got from Future Shop during the new years sales. In the PowerChute software that I downloaded for it, the "Current Status" tab shows the power supposedly being delivered by the battery backup.
I attached my tower's PSU to the battery backup of the UPS and used the PowerChute software to measure my computer while it was doing SMP folding. The PowerChute reported that the battery backup was providing 103W. I thought that was a little low for a Core i5 2500k OC'd to 4.2 GHz + Radeon 3650 idling through a 600W power supply that can't be anywhere near its max efficiency, so I tried measuring with my blue planet energy meter. The energy meter, measuring through the exact same UPS outlet, measured a more reasonable 141-143W as the power consumption.
Can I assume the UPS is underestimating the power consumption, or is it doing something devious like only giving me the "real" component of the power in its reading?
Thanks
Old January 24, 2011, 10:10 PM
It might be the active PFC on the PSU throwing the numbers off, but either measurement probably isn't very accurate. I would assume the general ballpark is right though.
Old January 24, 2011, 11:12 PM
id say the 143ish is more like it
http://www.hardwarecanucks.com/forum...review-20.html
but oc'ed? hmmmmmmmmmmmmmm
Old January 28, 2011, 06:28 PM
KaptCrunch's Avatar
your forgetting the charger side is also working on UPS try using the outlet on UPS with blue planet, not @ wall
Old January 28, 2011, 07:31 PM
The blue planet is attached to the UPS outlet, so the UPS charging current is not going through the energy metre. Right now my chain is going Wall -> UPS -> Energy Metre -> Computer PSU.
I had to reinstall my noisy Radeon 4870 (I can't even accept its fan speed at 32% ), so I have a new data set:
With the CPU OC'd and folding and the GPU at desktop idle:
  • The Blue Planet metre measures ~217W
  • The UPS software is seeing 166W
F@H & Power Consumption. Look no further. lowfat HardwareCanucks F@H Team 31 September 26, 2011 05:41 AM
Power consumption of 3D cards? walkingdog Video Cards 6 October 5, 2010 11:53 PM
PC Power Consumption Analysis MpG Reviews & Articles from the Web 29 June 11, 2009 04:23 PM
I DID IT!!!! Serious power consumption SKYMTL Power Supplies 10 February 16, 2008 07:16 PM
F@H vs. Power Consumption cujo HardwareCanucks F@H Team 14 August 8, 2007 07:32 AM
