Old January 19, 2011, 12:43 AM
^^^ no it is not the model
model is fsp saga II 35ow..please check my above post for specs
Old January 19, 2011, 01:25 AM
burebista's Avatar
Originally Posted by neojjjk View Post
+12v1 & +12v2 max output is 300w
300W/12V=25A.
You'll be fine as long as you don't overclock like crazy.
If it ain't broke... fix it until it is.
Old January 19, 2011, 04:18 AM
^^ Thanks mate ... no I don't overclock any hardware..
Old January 19, 2011, 06:53 AM
Soultribunal's Avatar
Somehow I doubt that unit will ever be able to give its rated output.
But its up the OP in the end if he wants to do it. I stand by my assessment of the unit.
ST
www.realhardwarereviews.com
Old January 19, 2011, 09:31 AM
found that some other forum members are using same psu for 5770 1gb...some are using the same for gts 250
Old January 19, 2011, 09:42 AM
burebista's Avatar
Use it man without fear. It's a Fortron not a craptacular no-name.
Old January 19, 2011, 10:18 AM
gingerbee's Avatar
look no one said it won't work just a lot of us don't trust lower end units is all. i wouldn't use it if i had another option but if you have bought it already and your not overclocking go nuts cause it just seems like you where waiting for someone to give you the answer you wanted instead of just saving i get what your all say but i won't push it that hard+ money is tight so i am going to run with it. it's not great but it's not a nightmare. "so run what you brung" i have 3 dead ones in my bedroom as i type this it's didn't kill any boards or parts just died an early death is all.
edit very cool i myself am trying to hold off till 8 cores sandy bridge but i hear ya
Old January 19, 2011, 10:44 AM
actually I am saving some money to buy a new rig after sellin this pc(except lcd & gpu)....planning for a 6/8 core setup..will get a good psu that time..
  #19 (permalink)
Old January 20, 2011, 11:25 PM
got the card..played 3 laps of motogp08..setting-everything high ,no aa ,res- 1366 x768 ,circuit-qatar ,losail
got 140+fps ,minimum was 96 ..
  #20 (permalink)
Old January 21, 2011, 04:46 AM
by the way, you wouldnt happen to want to buy a nice little cheap kill a watt would you?
im saying this because if you got doubts, keep an eye on the numbers youre pulling from the wall.
as long as you know what the efficiency of the psu is, well more or less, then just by looking at idle gpu
numbers you can most of the time tell if youre going to be ok or itll blow.
350W Mr. Gruntsworthy Power Supplies 4 April 6, 2009 05:23 AM
350W in HTPC (comes with Antec Minuet) Mr. Gruntsworthy Power Supplies 0 October 7, 2008 03:12 PM
Vangaurd: Saga of Heroes Zelzubub Gaming 12 August 23, 2008 10:21 PM
The saga of Daniel K Digitaldemon Audio 21 April 7, 2008 06:24 PM
FSP Fortron FSP400-60THN enaberif Power Supplies 0 August 20, 2007 11:10 PM
