Old January 12, 2011, 06:54 PM
Blu's Avatar
Blu Blu is offline
Default Need help picking a psu fast
I currently have a seasonic 400watt 80 plus psu to power the following,
890 AM3 Motherboard
Amd 550 Dual core (unlocked to quad)
blu-ray player/writer
sound card
HIS IceQ H567Q1GD Radeon HD 5670 1GB
TV Tuner card
PCI Fan cooler
3 80mm fans and three antec spot coolers and one 40mm fan
one sata controller card
5x 2tb green hard drives
1x 2tb black hard drive
Would that psu be enough or should I swap it for this cause it's on sale,
NCIX.com - Buy OCZ B-Stock ModXStream Pro 500W ATX 24PIN SLI Ready Modular Cables 135mm Fan Active PFC Power Supply - OCZ500MXSP-B In Canada.
Please help me pick fast!
Old January 12, 2011, 07:11 PM
Don't bother swapping, you're barely stressing the Seasonic as it is. Not to mention the OCZ would be a sidegrade.
Old January 12, 2011, 07:17 PM
gingerbee's Avatar
ya it's a seasonic so it will take that no problem unless you really want to buy the ocz, i grabbed one of those of a member and i am very happy with it not killer but very nice for the price range.
Old January 12, 2011, 07:22 PM
you are probably pushing 200 or so watts on load, i wouldnt bother sir :)
Old January 13, 2011, 05:17 PM
Your fine with what you have.
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old January 18, 2011, 09:07 AM
neojjjk's Avatar
just use this calculator
Antec Power Supply Calculator
I tried ..antec calculator shows 331 w for your rig and your gfx card do not require a high powered psu unit ..under load it consumes around 250w only.
Old January 24, 2011, 07:58 PM
Ctech's Avatar
Restricted Poster
Don't bother. Switch only if you upgrade GPUs.
Old February 12, 2011, 09:37 PM
i dont trust OCZ's brand.
Buying a GTX260, Need help picking PSU phantom478 Power Supplies 6 June 28, 2009 06:24 PM
Picking the right Card Heff04 New Builds 6 December 28, 2008 11:11 PM
Help picking a GPU xghostz Video Cards 42 October 14, 2008 06:27 PM
Need help picking a good but cheap PSU lanken123 Power Supplies 15 October 2, 2008 04:48 PM
The Barcelona is fast, REALLY FAST!: AMD Babrbarossa Press Releases & Tech News 2 April 25, 2007 08:02 AM
