Old December 29, 2010, 03:31 PM
Default What PSU wattage do I need?
I will be running a 950-i7 on a P6x58d-e with over 9 fans (mostly for the RAD) running about 4.2 24/7?
Old December 29, 2010, 03:38 PM
Jake_HT's Avatar
What and/or how many video card(s)..?
http://jakeht.deviantart.com/
Old December 29, 2010, 03:52 PM
2 gtx 460's
Old December 29, 2010, 04:29 PM
650w is capable but not too many support two gpus natively (don't have the 6 pins), a 750w should be perfect. If you want to go big then silver rated seasonic or any rebranded seasonic such as the xfx 850w can be found for around $130.
Old December 29, 2010, 04:37 PM
12v rating....lets see
HIS Radeon HD 6970 2 GB Review - Page 27/33 | techPowerUp
250 watts for the sli pair, add 50-100 watts if uber clocking too
for the cpu board give it 200 watts
another 50 for drives nd fans
up to 500 watts 24/7 on the 12v, so as per above :)
Old December 29, 2010, 04:44 PM
Thanks for the suggestions
Old December 29, 2010, 11:01 PM
Rayzer's Avatar
If you're not on a tight budget, I suggest getting a modular power supply. Makes cable management a breeze.
Old December 30, 2010, 06:25 AM
Try this...
Antec Power Supply Calculator
Cheers; Snarl
Another Guy From Canada
Old December 30, 2010, 06:33 AM
Im not sure what the minimum power wattage is but I know my Corsair HX 750 was able to handle a similar setup as yours... i7 920 @ 4.4 ghz gtx 460 sli both overclocked... and a watercooling system with 6 fans...
Thermaltake Launches Next Generation Toughpower XT PSU Series with Enhanced Wattage FiXT Press Releases & Tech News 4 February 5, 2010 07:02 PM
Low wattage, quiet PC. m0pelley99 New Builds 21 September 30, 2009 05:52 PM
Cooling wattage guess. Overclocker~4.1 Water Cooling 16 September 2, 2009 11:13 PM
how much wattage? quikgp Power Supplies 9 June 1, 2009 08:20 AM
brand & wattage ? Jim Power Supplies 5 May 28, 2007 04:58 PM
