Old January 2, 2008, 07:37 PM
curtispan's Avatar
Default Corsair 520HX enough for me?
I am planning to get a new PSU and I was wondering if this PSU would be sufficient enough for me. I find the 620 is a little over my budget so I will go with this one.
Specs:
AMD 4200+ AM2 oc'd 2.7ghz volt 1.45
Asus M2N-SLI Deluxe
G.Skill DDR2-800 2GB
XFX 7900GS XT not oc'd
Creative Audigy 4
2 Optical drives
2 HDD
3 120MM Tricools
1 200MM Tricool
Antec 900
Anything else I am missing?
If the 520w is not enough, could you recommend some other PSU that is modular but not as expensive as the 620?
Thanks
Edit: I've tried the extreme psu calculator, and I got a total of 430w, but I don't really trust it.
Old January 2, 2008, 07:40 PM
Power supply is plenty if you don't have that case yet I'm gonna strongly recommend staying away.
Old January 2, 2008, 07:44 PM
Babrbarossa's Avatar
Yeah- that'll be a great PSU fer ya
Old January 2, 2008, 07:45 PM
curtispan's Avatar
Thanks for the fast replies.
Yes I already have that case, but it seems fine to me. It is a dust magnet though. :P
Well I guess the 520hx is for me.
Old January 6, 2008, 08:15 AM
That power supply is fine with reserve if its working as spec'd.
Cambridge,ON
MSI Z77 M Power/Bios17.12
3770K@4.5ghz
Mushkin #997007
Noctua NH-D14
Gigabyte GTX 660
Seasonic X-660
Corsair 540 Cube
Noctua case fans
Intel SSD
Win 10 Pro x64
Old January 6, 2008, 09:50 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
It is more than enough for you. I actually think it will fit very nicely with that build.
Old January 6, 2008, 11:35 AM
Thund3rball's Avatar
Did someone say HX520?... I love mine :)
"this is not troll. this is real deal!" - hohohee
Desktop:
See the drop down!
Laptop: Dell XPS M1530 \\ T7500 2.2GHz \\ 3GB 667 \\ 6 Cell \\ 8600M GT \\ 200GB 7.2K \\ WSXGA+ \\ Bluetooth/Wireless \\ MS Blue Track Mini \\ Vista Ult. (RED)
HEATWARE
Old January 6, 2008, 07:55 PM
Amon's Avatar
Seems more than enough.
Buying New Ram: OCZ vs Corsair tgraszat14 RAM 2 February 5, 2008 11:27 AM
Corsair TX750W Cptn Vortex Power Supplies 5 November 4, 2007 10:55 AM
Nautilus 500 from Corsair... francois methot Water Cooling 36 April 25, 2007 09:09 PM
Corsair XMS2 Babrbarossa RAM 4 January 28, 2007 10:07 PM
