Old December 1, 2010, 09:25 PM
Mook06's Avatar
Default Silverstone Olympia OP750 - old but still good?
ncix has this psu on for very cheap this week, Silverstone Olympia OP750
NCIX.com - Buy Silverstone Olympia OP750 750W 20/24 Pin Power Supply ATX / EPS12V Active PFC 120MM Fan - OP750 In Canada.
everything looks good about it, overkill amperage for my use, i plan on grabbing a single GTX 460 1gB soon, and a few more HDD's
seems the fan may be noisy, but shouldn't be a problem with my low load and good air flow case, but i am pretty picky with noise so maybe i should steer clear
no sleeving = i may sleeve it myself
not modular = not a big deal i have a Fractal XL to hide the extra
it was released in 2007, so its a bit old, but thats not a big deal with a psu, unlike other tech
the price is killler though
any thoughts would be awesome
Old December 2, 2010, 04:51 PM
Mook06's Avatar
bump, is this psu still worth buying?
Old December 2, 2010, 04:59 PM
ZZLEE's Avatar
List out your specs fore the system. i5 and i7 are very voltage sensitve and if your planning on using one of them I would personaly go with a BRonze or Silver rated power supply .
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old December 2, 2010, 05:20 PM
CroSsFiRe2009's Avatar
Voltage sensitive? Efficiency? Those have nothing to do with whether or not it will power a system. There's no such thing as chips being voltage sensitive if the power supply is supplying proper, stable voltage within ATX spec.
That particular PSU may be a bit old but it'll power a 460 and whatever board/chip you choose without any problems. I'm not sure what OEM manufactured it or if its a Silverstone design but it shouldn't be too bad based on this review
PC Perspective - SilverStone Olympia 750W Power Supply Review
Even with a 500-600 watt power supply, it is more than enough for your needs although it may be cutting it close if you ever decide to get dual 460's in SLI.
Old December 2, 2010, 05:48 PM
Soultribunal's Avatar
I would go for the Strider Plus personally, THe olympia is an old unit that has seen its day by modern standards.
The Olympia is an average unit, FSP I think, might be an older enhance platform too.
Price is good, and if you want grab it it will power most of what you want to do with it.
However if you really want a solid unit from Silverstone, I vote the strider.
ST
www.realhardwarereviews.com
Old December 2, 2010, 06:26 PM
at that price i would buy 5+. go for it.
Old December 2, 2010, 07:23 PM
Mook06's Avatar
after reading a bit more i found out that its actually very quiet unit, but a few people were having squealing problems at high loads and had to RMA, so it seems it should be all good, i have free rma shipping with ncix so if it squeals i can swap it out
woops forgot to add, thanks for the input guys!
what is a good Media player for a good price or any suggestions Shadowmeph HTPC Systems & Software 4 December 19, 2009 11:27 PM
[WTB] Silverstone TJ07 mattlef Buy/Sell & Trade 5 June 9, 2009 02:39 AM
Silverstone LC-03 JD HTPC Systems & Software 9 March 19, 2009 09:49 PM
Comment Thread for Silverstone Olympia 650W Review SKYMTL Power Supplies 5 May 13, 2007 04:50 PM
