Old December 1, 2010, 10:49 AM
Default Powersupply suggestions for i7 hexa core + gtx 580 sli
Hi
I'm going to build an i7 hexa core with gtx 580 sli. What is a good kilowatt powersupply. I know enermax is good but it is bit too expensive, is coolermaster any good? Any suggestions are appreciated!
Old December 1, 2010, 01:54 PM
I don't know if it'll fit your budget but the antec high current pro 80+ gold seems pretty good.
NCIX.com - Buy Antec High Current Pro 1000W 24PIN ATX12V Active PFC 80 Plus Gold SLI Modular Power Supply 80MM Fan - HCP-1000 In Canada.
Old December 1, 2010, 02:03 PM
well, you may want to look at the hx line from corsair. 1kw and above, gives you room to spare for clocking, limiter off,etc.
Old December 1, 2010, 02:09 PM
Sagath's Avatar
A good quality 750w will run this setup, overclocked, just fine.
Wall Draw on my single 580 + 4ghz i7 930 is <450w. Again, this is wall draw, so when you account for ~80% PSU efficiency, I'm not even loading the PSU to 50%.
Originally Posted by Lpfan4ever View Post
AKG shot the hamsters, and then Perineum drove his Mustang with summer tires into the server.
Old December 1, 2010, 05:24 PM
I know it's not a 1Kw, but I got a smoking deal on a Seasonic M12D from NCIX - it's a 80+ Silver Certified Semi-modular PSU. Don't buy it at regular price, it usually goes on sale for about $129.00. Alternatively, you could go with a PSU from corsair as dangtx suggested.
Just dont cheap out when buying a power supply!
Motherboard: Asus Crosshair IV Formula - CPU: AMD Phenom II 955be - CPU Cooler: Corsair H50 Hydro Cooler - Video Card: XFX Radeon 5870 HD587XZNFC - Power Supply: Seasonic M12D 850W - Memory: G-Skill F3-12800CL9D-4GBRL - Case: Coolermaster Cosmos "S" - Hard Drive: Western Digital 1TB Caviar Black - DVD Drives: Samsung SH-223C & Lite-On iHAS124
Old December 1, 2010, 05:43 PM
I'd strongly recommend the Corsair HX850: NCIX.com - Buy Corsair Professional HX850W 850W ATX 12V 70A 24PIN ATX Modular Power Supply Active PFC 140MM Fan - CMPSU-850HX In Canada.
The price is a bit on the high side, but it's a Seasonic manufactured power supply with excellent performance. It does run a bit loud for my liking as I have an HX650, but other than that, it's an extremely solid unit. Plus, modular is always nice :)
As for kilowatt units, as suggested before, Antec makes very high quality power supplies. I believe there was a video on Youtube of the 1.2 kw model of the Antec HCP's delivering over 1600w's of power.
Old December 1, 2010, 06:04 PM
gingerbee's Avatar
seasonic. period but you pay for what you get love there stuff i only buy there brand for my personal pc
Old December 1, 2010, 09:00 PM
THANKS EVERYONE! I got Seasonic M12D ( NCIX.com - Buy Seasonic M12D 850W EPS12V 20/24PIN ATX Modular Power Supply Active PFC 80PLUS 8PIN PCI-E 120MM Fan - M12D-850W In Canada.). The sale JUST ended, it was $134.99. Hope it is a good one
Old December 1, 2010, 09:03 PM
Jake_HT's Avatar
Great choice.
http://jakeht.deviantart.com/
Old December 1, 2010, 09:25 PM
Only worry I have for the power supply is that it is two rail instead of one (i heard single rail works better with CF or SLI). How is the two rail configured? Which modular plug is rail 1 and which is rail 2. Can someone with the same PSU educate me?
GTX 580 or 470 sli for 3d vision Battery Video Cards 8 November 12, 2010 11:02 PM
SLI 260gtx (192 core) & 260 gtx (216 core)? Possible? Apathetik Video Cards 5 September 22, 2009 08:06 PM
EVGA GTX 260 Core 216 65nm SLi mchutch Video Cards 5 April 2, 2009 08:23 PM
