Old November 10, 2010, 07:49 AM
Default CM PSU making electrical buzzing sound
Just bought a brand new CM GX 750W PSU, after 2 days of use, an on and off electrical buzzing occurs, it's not constant. But after i shut down the com a less loud buzzing sound is heard from the psu I'm sure of it.It's non-stop, i have to switch off the main socket to eliminate the noise. What is happening?
Old November 10, 2010, 10:52 AM
a coil is vibrating on a frequency you can hear, that's all.
but are you completely sure it is the new psu? try to return it, even if it works fine it shouldn't buzz your brains out. but before that hook it to another power bar, line conditioner or other ups you may or not have around. or hook it up to another socket, room?
me bro's puter was buzzing a bit, the wall socket he was using was poorly grounded.
Old November 10, 2010, 07:20 PM
Yes, it's completely new but not fresh out of the factory of course. Is the buzzing sound an indication that the PSU is about to fail?
Old November 10, 2010, 07:29 PM
Soultribunal's Avatar
Well I would talk to CoolerMaster and see what they say. I Know people have RMA'd PSU's before for such things. IT doesn't always mean the PSU is failing, A lot of the times it's just coil whine. You can try a different outlet, or a power conditioner to see if that helps.
ST
Old November 10, 2010, 08:16 PM
Is coil whine bad for the PSU?
PSU making loud buzzing noise? cruisx Troubleshooting 2 October 18, 2010 12:24 PM
PSU buzzing sound in sync with HDD activity status? hedgehog88 Troubleshooting 6 July 27, 2010 07:45 PM
8800GT making a beeping sound when folding? Gunner86 Video Cards 13 March 19, 2009 02:28 PM
Buzzing sound from Sennheiser PC 350 nexus1111 Peripherals 1 January 27, 2009 06:43 AM
Electrical Buzzing Noise From PSU Johnnyl168 Troubleshooting 10 December 13, 2008 08:21 PM
