Old November 10, 2010, 08:26 AM
Default COUGAR SX700 PSU
This PSU is $100 after MIR, and it comes with COD Black Ops. Seriously considering getting it. Any objections?
Newegg.com - COUGAR SX700 COUGAR-SX700 700W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS SILVER Certified Modular Active PFC Power Supply
Old November 10, 2010, 08:28 AM
Soultribunal's Avatar
They are actually not too bad, check out Johnny Guru's site on them but I don't see why not.
ST
www.realhardwarereviews.com
Old November 10, 2010, 08:30 AM
martin_metal_88's Avatar
this PSU is good. If you want a PSU upgrade + black ops OEM there is nothing bad with it. But if thegame is not important to you I would go see some other PSU. Also, not in the right section. This belong to off topic or PSU. ( maybe more off topic ).
Old November 10, 2010, 01:18 PM
JD JD is offline
Thread moved to the PSU section.
Looks decent enough for $100 I suppose. And I guess the game helps reduce that cost even more. Obviously only but it if you need a PSU though, otherwise there's no point really since there's better PSUs to be had.
Old November 10, 2010, 03:51 PM
If you were going to buy blackops anyways it seems like a really solid deal (Makes the PSU only about 50 bucks or so...)
Old November 10, 2010, 03:58 PM
Ctech's Avatar
Restricted Poster
Looks good for ~$100 PSU. Black Ops as a bonus makes it sweeter.
Old January 8, 2011, 03:27 PM
sswilson's Avatar
Not exactly the same PSU, but this thread comes up with a cougar PSU search so I thought I'd drop a comment or two in.... ;)
Picked up a 700W PowerX unit ( NCIX.com - Buy Cougar Powerx PX700 700W ATX 24PIN 54A 12V 80PLUS Bronze 120MM Power Supply - PX700 In Canada. ) and wanted to point out that it is a two 12V channel unit w/ 30A per channel, isn't modular like the one originally mentioned, and doesn't appear to be the same quality. I do like the cable layout though.... there's a seperate Molex and Sata cable, as well as an extra long one that has both. No floppy connector hard wired, but there is a molex - floppy adapter included. (strangely enough... the P965 Dark board I'm stress testing with the PSU requires a floppy power connector.... ;) ).
Have to see how it holds up, but it looks fairly decent and came at a reasonable price when it was on sale.
More than one PSU? MobiusD Power Supplies 33 June 11, 2010 12:22 AM
[WTB] Dual (same) 700W+ psu, or 1200W+ psu 3.0charlie Buy/Sell & Trade 12 October 7, 2009 07:07 AM
About my PSU Kilauea Power Supplies 12 May 22, 2008 07:31 PM
need PSU suggestions, current PSU isnt cutting it Rains Power Supplies 13 December 11, 2007 08:53 AM
PSU Help BALISTX Power Supplies 2 May 16, 2007 08:06 PM
