Old October 28, 2010, 09:33 PM
Default Antec Earthwatts 430 concern
Hi all,
I bought the titled Antec power supply for a budget PC i'm building for my friend, however upon installing it I noticed it was missing the CPU plugin. Will it still function without this?
Thanks!
Wolf
Antec 900
Intel Core i5 @ 2.66GHz
Asus P7P55D motherboard
EVGA 9800 GTX+ Superclocked
4GB of Patriot Viper II DDR3 RAM
2X320 GB Western Digital @ 7200 RPM
Plextor DVD +/- RW
Corsair TX 750 W power supply
Windows 7-64
Old October 28, 2010, 09:44 PM
odis172's Avatar
Do you mean its missing the 4 pin P4 connector for cpu power?
Laptop: Lenovo T420 - Core i5 2520 - 8GB DDR3
Server: 2 xeon E5530 - Asus Z8N-D6 - 12GB DDR3 - 8x 500GB raid 50 - Perc 6/i - Compucase RA448A00
Old October 28, 2010, 09:45 PM
I know of 2 Antec Earthwatts 430W models, both have a CPU plugin. Only difference is one uses an 8 pin and the other is a 4 pin.
I'm assuming you got the one with the 4 pin connector, in that case you can just plug it in or use an adapter and it will work. I wouldn't recommend either though, getting another PSU would be my suggestion assuming you're not strapped for cash.
Old October 29, 2010, 07:00 AM
first of all whats the pc looking like, whats the part number on the unit and maybe a piccie of all the connectors? :)
Antec Earthwatts? laplapmax Power Supplies 4 October 26, 2010 08:35 PM
Antec TruePower or Earthwatts MarkOne Power Supplies 11 January 5, 2010 10:50 AM
[FS] Q9400, GA-X48-DS4, Mushkin Redlines, Antec 430 Basiq, fan adapters Lpfan4ever Buy/Sell & Trade 13 October 22, 2009 11:58 AM
Is the Antec Earthwatts 500W enough? Song Power Supplies 7 September 29, 2007 07:34 PM
