Old October 26, 2010, 07:56 PM
Default Antec Earthwatts?
Hi guys me again(NOOB)
i dont know what is Antec Earthwatts?
Could any one explain it little bit to me?
THanks for helping!
Old October 26, 2010, 08:16 PM
Antec Earthwatts power supplies are environmentally friendly power supplies... they carry the 80 PLUS certification (80% efficient) they use up to 33% less energy than a comparable supply without a reduction in performance, reliability or stability. Here a link:
http://www.google.ca/url?sa=t&source...dGU_DQ&cad=rja
Old October 26, 2010, 08:25 PM
I think it's a little cheesy that they're painting the newer ones green, but I'd trust an Antec Earthwatts in my system. I used the older 380W Earthwatts it in a low-end gaming rig (AMD Athlon X2 5200+, Radeon 3650) and over 2 years and ~10 LAN parties later, it's still ticking. I'll probably use that old PSU again in my main after I retire it to HTPC status, given that it will probably be more efficient than my 600W PSU drawing 1/3 of its rated power
Old October 26, 2010, 08:30 PM
OH i get it now..
it help you to save energy without reduction the performance.@
Old October 26, 2010, 08:35 PM
Antec's never die... I still have a couple AntecTruePower 430 watt psu's that I bought like 7-8 years ago... both are still running flawlessly.
Antec Looks to Release Antec Six Hundred Mid Tower FiXT Press Releases & Tech News 20 February 17, 2010 11:21 AM
Antec TruePower or Earthwatts MarkOne Power Supplies 11 January 5, 2010 11:50 AM
Is the Antec Earthwatts 500W enough? Song Power Supplies 7 September 29, 2007 07:34 PM
