<~----> Current Draw - Page 2 - Hardware Canucks
Old October 17, 2010, 08:11 AM
OK...here is my opinion:
Will the PSU run the sytem...yes (though a better one is recommended)
Will it run win7...not well unless you have >2gb ram
If this is just a cheap system you want to last a little while it should be fine running win xp, but if you want it to be use-able for a while longer gather up 2gb or more ram and get a better PSU. Even if the PSU can power the system it doesn't mean it is powering it well (voltages MAY be all over the place and may kill something or everything in your system).
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old October 17, 2010, 08:20 AM
Reyzac's Avatar
That's exactly it.
Eventually maybe I will, depending on what comes through my door.
Let's hope it doesn't
Who needs a real doctor when you got my machines and their scary needles?
Old October 17, 2010, 03:58 PM
ZZLEE's Avatar
glad to help :)
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old October 17, 2010, 07:43 PM
JD JD is offline
I would also strongly advise against Windows 7. Windows XP will have to do.
However if gaming can be avoided (I really wouldn't want to game on a P4 and FX5200 personally), may I suggest giving Ubuntu a shot? It should run quite nicely and look more up-to-date than XP.
Old October 18, 2010, 04:06 AM
Reyzac's Avatar
Ehhh... thanks for the suggestion, but I'm not a Linux guy. IDK what it is, I just don't really like it.
I play some games on the POS I'm running right now, the thing has a Celeron and IG going for it
I'm sure a 0.3GHz increase in speed and the addition of a vid card will improve my performance.
Old October 18, 2010, 05:32 AM
my advice? save a hundred and spare for athlon II + mobo + ddr2(2-4gb) + another hundred or so for a used gpu
Old October 19, 2010, 03:57 AM
Reyzac's Avatar
Oh, I'm likely getting a new comp sooner than later, but I want to replace the crappy thing I'm on now until then. Certainly not a permanent solution.
Old October 23, 2010, 09:04 AM
Reyzac's Avatar
Default Surprise... kinda
Well, I actually unpacked my RAM yesterday and realized that it is, in fact, more than 2GB.
It's 2.125GB.
Still not good enough, I gather?
Can an excession power draw blow up your PSU? OTCM Power Supplies 8 January 24, 2010 05:08 AM
Draw your piggie.. omgwtf Off Topic 26 March 21, 2008 03:23 PM
How much power does 3870xfire draw? Mech0z Video Cards 1 December 10, 2007 01:28 PM
Current draw of 3 120MM fans? sswilson Water Cooling 3 September 14, 2007 03:32 PM
