Originally Posted by _dangtx_ could your highness pretty please enlighten us upon the above? like i said before, the consumer needs to know. :) |
Honestly, I just spent several hours fighting to transplant one of my PCs into a Lanboy Air, I'm tired, and I'm not in the mood to go searching around for the forum thread somewhere else where the issue was discussed in more detail. Ask me tomorrow or the day after and I might have time to do that.
Originally Posted by KaptCrunch BS i've had a few in my day for transformer took a dump, no fire but a smoke show
while the protection you speak is dumb when it comes to hardware fail |
I have no idea what the hell you're talking about. I'm trying to understand what you said, but it reads like gibberish to me. I'm not even sure anything you said has a relationship to the actual discussion in this thread.
Originally Posted by Soultribunal Somtimes it is better to give options. And if no one answered the direct question, am I not included in that? Sorry Zero, sometimes your post then Retort gets confusing on how I should follow it.
I just merely hoped to give him better direction and confidence in the options out there.
Sometimes things are not just black and white.
ST |
Like I said, there was nothing wrong with your recommendations or the fact that you gave them. The only thing I was pointing out was that nobody else had actually given the answer to the problem posed in the original post.
Originally Posted by Patramix not to hijack the thread, but what would you guys recommend
the Corsair Professional HX750W or Corsair Professional Series Gold AX750, there like a 20-30$ difference, is it worth it or an other 750W silver/gold under 160$ shipped, the XFX 850 BE is currently 145 at NCIX witch i currently own as well in my main system, just prefer the look of the corsair for my new build :)
i plan on getting a PSU this week-end for my new build, trying to keep it under 160$ shipped(for the HX) the Gold is around 27$ more, in the long run is it worth it for the gold? |
The AX750 is not worth the increase in price over the HX750, unless:
-You are a silence freak, since the AX750 uses a quieter fan and the fan does not even turn on until about 300W of load.
-You are crazy about efficiency, although the AX750 is only about 1-2% more efficient than the HX750 at any given load.
-You want the fully modular aspect of the AX750.
Unless one or more of those things is a deal breaker for you, get the HX750.
