-   -   question 850 watt psu xfx! (http://www.hardwarecanucks.com/forum/power-supplies/36529-question-850-watt-psu-xfx.html)
r.o.g September 24, 2010 06:17 PM
Hello everyone! this is my first post in the forum, I'm from Argentina and sorry for my poor English , I wanted to ask a question to the community:
850watt psu xfx supports the following configuration:
i7-975
rampage 3 extreme
12 gb kingsnton hyperx to 2000MHz
3 x gtx 260 black edition (3 way sli).
5x500gb hard disk at 7200 rpm
2x60 gb ssd
12 cooler of 120mm
or will I have to change the psu?
Soultribunal September 24, 2010 07:01 PM
i7-975
rampage 3 extreme
2x60 gb ssd
12 cooler of 120mm
Should be just fine.
ST
_dangtx_ September 24, 2010 08:39 PM
hola dude, welcome aboard.
your gpus will pull around 400 watts max in normal gaming mode or 555w under extreme loads(furmark,usually not seen in normal gaming mode), add another couple hundred for the rest of the system. the psu can do 740w on the 12v, so you will be pretty fine.
what case do you have that takes 12 fans? :)
r.o.g September 25, 2010 07:09 AM
..... The 12 thermaltalke coolers are a mozart tx.
Thank you very much for your help!
Thanks for answering my questions!, then buy third GTX260 video card xfx be, I thought I was short of power with this source.
_dangtx_ September 25, 2010 12:10 PM
no worries man. hmm..you may want to do sli with more modern cards, hold off buying a third 260.
r.o.g September 26, 2010 03:41 PM
I would like to fulfill the dream of putting together a 3xgtx260 sli .... but if not working properly. vere in buying the gtx 460 SLI
Greetings!I would like to fulfill the dream of putting together a 3xgtx260 sli .... but if not working properly. vere in buying the gtx 460 SLI
Greetings!
_dangtx_ September 26, 2010 04:00 PM
well, i cannot go against your dreams.
but tri-sli 260 is less practical than sli 460, which beat gtx 480 (except on insane resolutions)
r.o.g September 27, 2010 03:45 PM
Una GTX260 3-SLI es el equivalente a hd 5850?
Greetings!
_dangtx_ September 27, 2010 09:23 PM
depending on the scenario, more or less. or a bit better? again, depending on where.
