Old December 8, 2007, 05:44 AM
Nodscene's Avatar
Default Modular power supplies - what do I really need etc
I've searched the forums and I've read quite a bit of Skymtl's reviews but as usual I'm left with more questions. I'm always looking to max out the price/performance ratio so I think I could do very well in the $130 range give or take. Here is what I'm thinking of buying....
Q6600 (probably won't overclock)
Intel Badaxe MoBo
Patriot Extreme 2x1gb pc2-6400 cl4.4.4.12 (may go with 4 gigs)
EVGA 8800GT Superclocked 650mhz 512mg DDR3
4x Seagate 750gig 7200.11 (eventually)
Probably a SATA burner or 2
HT Omega Claro 7,1 sound card
I also have 2 external hd enclosures right now, both firewire.
I'm also trying to decide between the NXZT Hush and the Silverstone Kublai KL01B
EDIT: I'm thinking of also getting an Artic Freezer to go with this but I doubt they draw much power
Overall suggestions would also be welcome. Some of my choices are due to the fact that I will be installing the hackintosh so I can run Logic and get rid of my iMac. I've been seriously considering the Corsair HX520 but was wondering if there was other PS I should be considering.
Thanks
Old December 10, 2007, 07:45 PM
jonnyGURU's Avatar
Registered User
You can definitely get something very nice and adequate for your build with $130.
The HX520W is not a bad choice.
Old December 10, 2007, 10:15 PM
Cptn Vortex's Avatar
I agree, the Corsair PSU's are very very good. I was running the HX620W before I got my second GTX, and it was perfect, while remaining very stable, and very silent. I now have my 1000W Ultra, which is a killer product, but a little loud. The day the 1000W Corsair comes out, I will get one methinks!
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
Old December 11, 2007, 04:49 AM
jonnyGURU's Avatar
Registered User
You think the Ultra 1k is loud? Hmm... Might be the pitch of the fan. I didn't think it was loud, but it did have a bit of a hum to it.
Choice amongst 4 power supplies and a little help Eleazar Power Supplies 12 October 20, 2007 10:21 AM
High powered power supplies with loud fans Misoprostol Power Supplies 8 April 23, 2007 01:34 PM
SLI and CrossFire Push Power Supplies to the Limit Gav Troubleshooting 3 February 12, 2007 03:09 PM
Power Supplies enaberif Power Supplies 1 January 24, 2007 11:17 PM
