Old August 16, 2010, 03:15 PM
JD JD is offline
Default Another UPS Thread...
However my needs are a bit different. I only need around 100-150W out of it, and really just long enough so that my server can shutdown properly. Seems to really hate having the power die on it as it won't start up afterwards (I have the BIOS to always power on). It gets stuck in a constant loop of power on/off. And once I manually power it up, then the drives need to re-sync since I use Windows RAID1.
Also is it possible for it to detect and boot up once the power is restored? I'm guessing not, but that would be nice if it was possible. I guess another option would be to have the machine go to sleep rather than shutdown, then have it wake up when power is restored? Not sure if that's possible either though.
So looking for like 10 minutes (or more depending on price) runtime and something of decent quality but under $100? I think it should be feasible...
Never owned a UPS before though, so if there's anything else I need to do, please do educate me
Old August 16, 2010, 06:53 PM
19 minutes for a 150 watt load is doable on your budget.
Buy UPS/Power Protection - Price: $50 - $75 - DirectCanada
amd pm with ncix
Old August 16, 2010, 07:15 PM
ZZLEE's Avatar
Default Do you have a "Cosco"
NCIX.com - Buy APC BACK-UPS ES 550VA 120V UPS 8 Outlet 365J RJ-11 Protection - BE550G In Canada.
I have two 350 they do ok but I think fore what you want the 550 or higher.
These have a software shut down on them it takes one USB port on the back of the computer.
If you use there software you can ajust the shut doun to your preferances.
Go with one with one with the outlets on the top theyu are newer desines.
Cosco is a cheep place to find them if you or frend have a Cosco card.
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old August 16, 2010, 07:31 PM
JD JD is offline
$67.79 shipped a good price you think? Dell currently has it on sale. It's of the Canadian version if that matters.
Old August 16, 2010, 07:45 PM
ZZLEE's Avatar
shopRBC.com :: APC Back-UPS ES BE750G 750VA 120V Desktop UPS w/10 Outlets Shop RBC " on Sale"
All canadian means ia there is French pacakaging and language suport fore the program.
They also have 550 fore 59 $ also
Old August 17, 2010, 05:59 AM
JD JD is offline
Pushing the $100 price point, and I'm assuming I'd have to pay for shipping and then HST on top of that. Dell is free shipping at least, but it's the 550VA unit.
Old August 17, 2010, 06:17 AM
ipaine's Avatar
The 550V should give you about 10 minutes of runtime for 200W. So really that is all you should need.
I looked and that one at Dell for $59.99 is most likely the best price you will find. That is for the BE550G-CN. That is what I would get.
"Nothing sucks more than that moment during an argument when you realize you're wrong."
Old August 17, 2010, 07:20 AM
theres a place in toronto where refurb old school apc 1000's go for around under 50 buckers. recertified. for the life of me i cant find it anymore lol. but be aware, those things take up space and weigh a ton. i shouldve taken the truck on that one visit.
Old August 17, 2010, 10:42 AM
lcdguy's Avatar
i think the company your thinking about is called excessups and they are also on ebay.
Old August 17, 2010, 11:01 AM
nope, not that one. but thanks for adding another one to me list :)
Another UPS thread... Delavan Power Supplies 14 May 28, 2010 04:19 PM
UPS - What's this mean? JD Off Topic 13 December 18, 2009 09:42 AM
UPS RIGENSTEIN New Builds 5 November 11, 2009 01:43 PM
UPS again... zlojack Off Topic 23 February 5, 2009 11:22 AM
UPS, at it again Dr_BenD_over Off Topic 14 October 3, 2008 09:21 PM
