Old August 14, 2010, 01:54 PM
Originally Posted by chriskwarren View Post
Ugh. Missus absolutely hates the power cord running along the hallway, and it only solves the problem partially. I'll have to think of something else maybe.
Install a new circuit in the room the folding rigs are in?
Old August 14, 2010, 02:14 PM
chrisk's Avatar
Folding Captain
I am not sure that is possible. If I did not rent, I would look into it. Any idea of the cost?
Fold for team #54196
Old August 14, 2010, 02:58 PM
The electrical panel is in the same room, right? You could hire an electrician, but if you want to do it yourself it's maybe 50 bucks worth of supplies.
Old August 14, 2010, 06:16 PM
Arinoth's Avatar
You live in a basement apartment, does it not have drop ceilings? Could you not hide said extension cord in the ceiling then come down on the tile/area that needs it so you'll only see an extension cable running from the ceiling at one spot rather then the entire hallway?
Here I am: here I remain
Old August 14, 2010, 06:42 PM
chrisk's Avatar
Folding Captain
No tiles...gyprock...would have to cut holes
8 Pin Power extension Computergeek Power Supplies 11 November 5, 2010 12:36 PM
3.5mm extension cable: Does quality matter? Scart Audio 6 August 30, 2009 10:17 PM
extension for usb motherboard cable quikgp Peripherals 9 May 13, 2009 10:53 AM
Power Supply Requirements enaberif Power Supplies 9 August 1, 2007 02:22 PM
Power Requirements enaberif Power Supplies 6 July 10, 2007 06:20 AM
