Old July 25, 2010, 01:21 PM
Default Are my PSU voltages too high?
My computer is dead but the fan for my PSU still turns.
I have measured the voltages out of my PSU and get the following readings:
12V measures at 12.7 volts
5V measures at 6.2 volts
3.3V measures at 4.2 volts
Should I conclude that my 3 months old Corsair TX750 is defective? Did it kill my computer?
I have a high quality voltmeter and I am sure the readings I get are precise.
Old July 25, 2010, 01:24 PM
sswilson's Avatar
Readings from a PSU that isn't under load can't really be counted on as a diagnostic tool.
Old July 25, 2010, 01:41 PM
My PSU was under light load. The PSU fan was turning and a HD and a case fan were connected also. Obviously I could not connect anything else since my MB is dead.
Old July 25, 2010, 01:52 PM
Those readings range from out of spec to way out of spec, but I still wouldn't write off the PSU until you test it in an actual machine. Those components are loading it a little bit, but not enough to be sure that you're getting valuable readings.
Old July 25, 2010, 01:54 PM
MpG's Avatar
MpG MpG is offline
It doesn't look good, but it's hard to say - if there's not enough load on the 5V rail, most PSU's won't work properly. Would be good if you could switch a few molex pins and run a couple fans off the 5V rail, just to give it a little load.
Old July 25, 2010, 01:59 PM
I am afraid to plug it in another computer. If it is defective it might kill the second computer as well.
Old July 25, 2010, 04:25 PM
5 and 3.3 look scary lol.
12 is not that bad. well bad but i figure it could work with just that one up. dont plug it in anything else if youve measured properly.
unless you can hook it to a crap load of juice needy fans or something like that
Old August 19, 2010, 11:12 PM
Those voltages are too high, especially the 5V and 3.3V lines. Are you sure those are being measured accurately? Have you tried another multimeter? If you're sure they are being measured correctly, it would seem likely that your computer could have been damaged by overvoltage.
ups systems
Old August 20, 2010, 01:09 AM
The thing needs to be placed under load before proper measuring. a case fan and an HDD isn't considered a load.
Old August 20, 2010, 08:06 AM
When I communicated those voltages to Corsair they immediately concluded that my PSU was defective. Fortunately, nothing else was damaged. My computer runs fine with another PSU.
My replacement PSU arrived from Corsair yesterday. I will install it this weekend
OCZ High-Performance PSU Meets the Demands of Gamers and System Builders with Low-Profile Cabling mikellini Press Releases & Tech News 29 June 10, 2010 06:40 AM
Computex 2010: ADATA's New PSU Series & High Performance Flash Products SKYMTL Press Releases & Tech News 4 June 6, 2010 10:45 AM
Weird PSU Voltages...is this OK? Oversized Rooster Power Supplies 7 October 21, 2008 04:25 PM
Cooler Master Has First Ever 80 Plus Silver Certified High-Watt PSU Hardware Canucks Press Releases & Tech News 0 May 26, 2008 10:41 AM
