Old July 19, 2010, 01:11 PM
gambel626's Avatar
Default What power PSU should I get?
I have my new rig all planned out and the only thing that I am somewhat lost about is the strength of the PSU. The system is as follows:
Mobo- Evga p55 FTW
CPU- i5 750
GPU- GTX 460 Superclocked 768mb in SLI
Mushkin Ram
640 gb Western Digital Black
Samsung DVD Burner
I want a PSU that will provide me enough headroom for my future upgrades which might include:
SSD-100% chance of getting
GT 240 for Physx-75% Chance of getting
Fan Controller- 25% Chance of getting
I know that for the basic setup a good 750w PSU is enough but how much wattage would i need if I add in those upgrades at a later time, the one I'm most worried about is adding in the dedicated physx card.
If it Ain't Broke, Hit it Harder
Old July 19, 2010, 01:24 PM
I would recommend 600W at least.
Old July 19, 2010, 02:17 PM
Smoothie's Avatar
He's running two Gtx 460's so I would recommend the Seasonic M12D 750W: NCIX.com - Buy Seasonic M12D 750W EPS12V 20/24PIN ATX Modular Power Supply Active PFC 80PLUS 8PIN PCI-E 120MM Fan - M12D SS-750 In Canada.
Old July 19, 2010, 02:51 PM
cheapest way out for you to have room for clocking both gpus and the cpu would be a 700 watter,well 750, from corsair or the above. altough without oc'ing the rig should need maybe 350-400 watts on the 12v i think. add another 100-200 with oc.
Old July 19, 2010, 03:50 PM
Eldonko's Avatar
Hardware Canucks Reviewer
I would get a Corsair hx750 or Silverstone ST75F or similar. Dont cheap out on the PSU it is worth a few extra $ to get a good one.
Old July 19, 2010, 04:22 PM
gambel626's Avatar
I have found three psus that I find good and in my price range.
Corsair hx 750- $150
Silverstone strider plus 750- $123
Silverstone strider plus 850- $140
All psus are 80+ silver and also modular right now I am leaning more towards the strider plus 850 as it has a good price point yet and offers me a lot of room for exspansion. Which one would you guys pick?
Old July 19, 2010, 04:24 PM
I'd go with the 750W for your system. No need to spend more for power that you don't need.
Old July 19, 2010, 05:36 PM
NCIX.com - Buy Corsair TX750W 750W ATX 12V 60A 24PIN ATX Power Supply Active PFC 140MM Fan - CMPSU-750TX In Canada.
price match if needed
Old July 19, 2010, 05:42 PM
martin_metal_88's Avatar
Like zero said. No need for more then 750W unless you want to add A LOT in the future like a complete WC loop then I would go with the Strider plus 850. I am using this PSU in my system with a GTX260 + GTS250 a Oced CPU and a complete WC loop and he stand just fine and cold.
Old July 20, 2010, 12:45 PM
Smoothie's Avatar
Neither of those, the one I gave you a link to is my choice. You can't pass up this great deal on a legendary PSU. I also love how it is a 2 rail design. Seasonic all the way bra.
550W PSU to power a 4890? Caldezar Power Supplies 10 July 25, 2009 07:06 AM
Looking for a low power (but good) PSU foxman Power Supplies 14 November 19, 2008 09:15 PM
any power chord on PSU works fine? g3p3nk Power Supplies 5 August 14, 2008 02:40 PM
Mobo Power exstension cable/PSU frosty Power Supplies 1 May 31, 2008 08:19 AM
Corsair PSU...Not enough power? random_2 Power Supplies 43 March 12, 2008 05:09 PM
