Old July 5, 2010, 07:44 PM
kendallcschm's Avatar
Default How Many Pins?
i have the new ASUS M4A89GTD PRO/USB3.0 and the CPU power is capable of 8pins.. i only plugged in a 4 pin... how many should i have plugged in?
Old July 5, 2010, 07:52 PM
4 is fine, unless youre doing major clocking on a quad
Old July 5, 2010, 07:54 PM
stoanee's Avatar
I always plug in as many as possible, If there is room for 8 then plug in 8. Is there a particular reason you only plugged in 4?
heatware
Old July 5, 2010, 08:01 PM
Soultribunal's Avatar
PLug them all in. There is no real reason not to in all honesty.
ST
www.realhardwarereviews.com
Old July 5, 2010, 08:20 PM
CMetaphor's Avatar
Quadfather
I always thought that an 8-pin over a 4-pin has more to do with the PSU itself than the mobo. What I mean is: A multi- 12v rail PSU may not provide sufficient power using only 2 rails (which is all you get when using a 4-pin, 2 grounds and 2 +12v) so they put an 8-pin which can have 4 connections to 4 separate 12v rails...
But if you have a single-rail psu, I don't see why it would make a difference at all.
Old July 5, 2010, 09:38 PM
No. PSUs do not supply single connectors from multiple rails. The real reason is to divide the current draw between a larger number of conductors, but realistically that isn't an issue except in the most extreme circumstances.
Old July 5, 2010, 10:17 PM
Caldezar's Avatar
Personally, I don't think it matters. But if the board has an 8 pin socket, and your PSU has an 8 pin lead... Why wouldn't you?
Old July 5, 2010, 10:30 PM
ive seen some inhell boards not boot because of the 8 pin. nothing a 3 dollar 4 to 8 pin connector cant fix! :)
nGear 4 Pin P4 Power to 8 Pin Epc Power Adapter Cable - DirectCanada.
Old July 6, 2010, 06:38 AM
Bond007's Avatar
Summary:
If your board and PSU have 8 pin use it.
If your board has 8 and PSU has 4, but it boots with the 4 (most of the time it will) you are fine except for high power CPU with a huge overclock
If your board has 8 and PSU has 4 and it doesn't boot, then get a new PSU or one of the connectors mentioned above.
Old July 6, 2010, 09:12 AM
Shadowmeph's Avatar
I didn't know that you could run a eight pin with just four pins , not that I would if it has eight pins and my psu has a eight pin plug then I use it.
x58 Bent Pins: Updated. JORD4N CPU's and Motherboards 7 October 28, 2009 09:47 AM
OMG 2 Pins On The CPU Socket Are BENT ! JORD4N CPU's and Motherboards 23 October 20, 2009 05:57 AM
[WTB] Lian Li Fan Push Pins miggs78 Buy/Sell & Trade 3 September 11, 2009 12:27 PM
LGA775 Push Pins (OCZ Vendetta II) Mr. Gruntsworthy Air Cooling 11 October 11, 2008 09:56 PM
Can't get pins into X Bracket for Thermalright Ultra 90 Pylonman Troubleshooting 3 March 10, 2008 07:42 PM
