  #21 (permalink)
Old July 7, 2010, 01:57 PM
MpG's Avatar
MpG MpG is offline
Originally Posted by Zero82z View Post
So in other words, the current going through each conductor decreases. Which I'm pretty sure is what I said...
If that's what you meant, np. I've always used the term "Current draw" to mean total, that's all.
The 24-pin ATX connector only has two +12V wires. Those are mainly dedicated to powering PCI-E cards and other motherboard components. Most if not all of the CPU's power requirements are provided by the 4-pin P4 or 8-pin EPS12V connector.
Just pulled up an ATX24 pinout. Damn, you're right. And the old 20-pin only had a single 12V+ line. In which case, I guess there could be a pretty significant difference between 4 and 8 pin. And those motherboards offering dual 8-pin or an extra molex connection don't look quite as stupid any more.
  #22 (permalink)
Old July 7, 2010, 02:22 PM
sswilson's Avatar
Originally Posted by Shadowmeph View Post
I didn't know that you could run a eight pin with just four pins , not that I would if it has eight pins and my psu has a eight pin plug then I use it.
Every new motherboard I've purchased over the last few years has come with a 4 pin blanking plate over the second half of the receptical to make it easy to know where to plug the 4 pin plug if that's all you have.
  #23 (permalink)
Old July 7, 2010, 09:44 PM
Bad wording on my part.
x58 Bent Pins: Updated. JORD4N CPU's and Motherboards 7 October 28, 2009 09:47 AM
OMG 2 Pins On The CPU Socket Are BENT ! JORD4N CPU's and Motherboards 23 October 20, 2009 05:57 AM
[WTB] Lian Li Fan Push Pins miggs78 Buy/Sell & Trade 3 September 11, 2009 12:27 PM
LGA775 Push Pins (OCZ Vendetta II) Mr. Gruntsworthy Air Cooling 11 October 11, 2008 09:56 PM
Can't get pins into X Bracket for Thermalright Ultra 90 Pylonman Troubleshooting 3 March 10, 2008 07:42 PM
