Originally Posted by Zero82z The resistance is the same. The current draw is what decreases. |
The current draw isn't going to increase unless the system actually demands more current. So you just get a situation with the same current spread out over more conductor area, with a correspondingly smaller voltage drop and I2R losses.
I've never seen a straight answer on how much benefit the extra four wires are. Since a portion of the mobo power is already coming in via the 24-pin plug, it's actually a case of 24+4 pin plugs versus 24+8 pin plugs. Although I think the 4/8 pin's closer proximity to the power circuits and socket is supposed to matter too.
