Old July 1, 2010, 11:55 AM
:facepalm:
on paper theyre all the same. perhaps the above might work. unless its for a low end pc, i wouldnt bother.
Old July 1, 2010, 12:37 PM
Ummmmm...extension cord?
Heavy-Duty Air Conditioning Cord | Canadian Tire
Old July 2, 2010, 09:48 AM
Originally Posted by Zero82z View Post
Like I said on another forum where you made this exact same thread, basically any cheap power cord will do.
Yeah, there was a bit of a rush initially so I cut-and-pasted the thread when there was no response several hours later. Turns out the rush was unnecessary. Regardless, I find it's a good idea to tap multiple resources whenever possible, I appreciate the often varied opinions of each community.
Originally Posted by Arinoth View Post
All power cables are the same damn thing. They are just three wires in there of same thickness and insulation, as zero has stated any wire that is 3 pronged and has the same 'opening' to plug into a psu will work. Its simple electronics
That was my assumption but I prefer to be on the safe side. I'm no electronics expert, I don't pretend to know anything. Lots of misinformation out there, people trying to hock premium cables on the unwary. I have no intention of dropping a large sum of money on super high end cable, but I do plan to at least buy the same gauge (14 AWG, etc) as the cable I'm currently running, even if it means spending a little more.
Thanks, all. I think now I have more than enough info to make an informed decision.
NEED a 4870x2 Power Cable AmuseMe Video Cards 4 June 18, 2009 08:58 PM
Power a fan with a floppy power cable? andynerd Air Cooling 4 December 26, 2008 01:50 AM
Mobo Power exstension cable/PSU frosty Power Supplies 1 May 31, 2008 08:19 AM
Desperate: Power cable for ASUS Xonar DX scrawledinwax Audio 27 May 13, 2008 09:22 AM
power/reset button and cable magictorch Cases 2 November 28, 2007 01:09 PM
