Old October 30, 2010, 07:52 AM
KaptCrunch's Avatar
Originally Posted by Computergeek View Post
lol nope.
what 8 pin connection you are talking about? MB power or PCI-e
those connections aren't the same for the polarity changes and plug looks same but isn't
Old November 5, 2010, 12:36 PM
Newegg.ca - NZXT 9.84" 8Pin Motherboard Power Extension Cable Model CB-8P
Newegg.ca - StarTech 8" EPS 8 Pin Power Extension Cable Model EPS8EXT
pricey little c-rappers if i might add. when you asked i figure out converter instead extensions (i somehow blanked) . If theyre *real extensions* they *should work but fortunately for them they give zilch-warranty for this kind of stuff [shock] At least NZXT cable should work.
btw. why are these needed in your pc case? Usually 24-pin + 8-pin EPS came to be pretty long cables >20in, closely following those insanely 28-30 PCIe 6+8 cables. So additional extension seems pretty obsolete.
ATI Radeon 2600 PRO 6 pin power plug dodge Video Cards 1 May 26, 2010 09:35 PM
3pin to 2 pin power led? BobbyLou Troubleshooting 4 January 15, 2010 01:29 PM
4 pin power enough for QX9650? howdid CPU's and Motherboards 8 August 1, 2008 05:46 PM
6-pin PCI Express to single 8-pin no_pulse Power Supplies 12 July 8, 2008 04:46 AM
3 Pin to 4 Pin Fan Plug Adaptor? Thund3rball Video Cards 6 March 25, 2008 01:46 PM
