Old June 28, 2010, 03:52 AM
Default Silverstone Strider Plus 750W or Corsair HX 750W
Hello i got nearly all the things for my new computer.
Which of these 2 power supplies will be best? If there is a difference in the prize, it doesnt matter.
Corsair HX Series, 750Watt - Black
Strider Plus 75F-P, 750Watt - Black
My setup is:
Motherboard: Gigabyte GA-870A-UD3 SATA3 USB 3.0
Processor: AMD Phenom II X6 1055T 2,8Ghz. Boxed CPU
Video card: ATI Radeon 5970, 2GB GDDR5 Ram, PCI-E
Ram: KINGSTON 8GB DDR3 -1333MHz
Harddrive: Samsung 1000GB SATAII 6 Silent Fluid Engine 7200rpm.
Drev: Samsung 22X DVD/RW Dual layer SATA
Sound card: 8 Kanals HD audio
Netkort: 100/1000MB/s RJ45
Case: Cooler Master 690 II Advanced, USB and lyd on front. 1X120MM + 3X140MM coolers
Thx for viewing this, and if you reply
Old June 28, 2010, 05:21 AM
Soultribunal's Avatar
Either One will work perfectly in that setup. As well both Power Supplies you have choosen are quality designs.
Personally I would opt for the Corsair only for the warranty Length.
Regards,
ST
Old June 28, 2010, 09:47 AM
ForTheGG's Avatar
+1 for Corsair. In my opinion, their PSU's are unmatched in many regards. If you can hold out, you should wait for the AX series of PSU's to be released. They're an 80+ Gold lineup of PSU's and are all 100% modular.
"Sang Noir"
-Cooler Master Storm Sniper Black Mesh Edition
-Intel Core i7 920 D0 @ 4.116GHz 1.318VCore 24/7 HT On
-Corsair H-50 + 2x Cooler Master R4
-Asus RoG Rampage III Extreme
-6GB OCZ Platinum Triple Channel DDR3-1600 [7-7-7-20]
-2x EVGA GTX 295+ Quad SLI
-Corsair HX-1000
-WD 160GB Raptor 10000RPM
-WD 1000GB Black 7200RPM
http://valid.canardpc.com/cache/banner/1249140.png
Old June 28, 2010, 10:14 AM
The HX750 is the better PSU.
Old June 28, 2010, 10:51 AM
Thanks.
Now i know what to buy :) thumps up
question about corsair 750w silencer ToXic Power Supplies 7 August 7, 2009 07:15 PM
Asus P5Q Pro And Corsair 750W elec999 CPU's and Motherboards 12 December 7, 2008 09:25 PM
Silverstone Zeus 750W Mulder Power Supplies 14 June 25, 2008 09:49 PM
