Old June 18, 2010, 07:49 AM
Charmster's Avatar
Default Power Supply and Fans
Hello!
This is my first buiild and I would like to add more fans.
What do I need to connect all these fans together and then to the power supply?
How many fans can I connect together (is there a limit)?
Thank you for your time
Old June 18, 2010, 08:17 AM
jcmaz's Avatar
Just get some 3pin to molex adapters (you fans should come with one). And plug the molex end into the PSU.
-Plato
Old June 18, 2010, 08:36 AM
Soultribunal's Avatar
I don't think I've ever run into a limit on connecting multiple fans together (Daisy Chaining).
So basically add what fans you need to, like jcmaz said and plug as many in as you need.
ST
www.realhardwarereviews.com
Old June 18, 2010, 10:48 AM
Fans typically use at or below 0.5A of current each. A typical molex connector can handle up to about 15A of current safely. Unless you plan on chaining together more than 30 fans or so, you should be good.
[WTB] power supply 650+ power supply j-ronde Buy/Sell & Trade 1 March 31, 2009 09:45 AM
