Old June 11, 2010, 09:46 AM
Default is this power enough for my system
do i need to upgrade my power ?
i had Gigabyte 585W ODIN
Gigabyte 585W ODIN - ATX 12V v2.2, 120mm Fan, RoHS, Sleeved Cabling (24EPG-P46AC2-21R) | Techbuy Australia
my system
I7 920
gigabyte GAx58a udr
HD 5850
and can i over clock with this power ?
i just opened the unit
the code said : FSPXXX-60GLY(NEW2) and there is a tick beside 460W
this pic exactly like what in my psu
http://img261.imageshack.us/img261/9963/dsc02030i.jpg
Old June 11, 2010, 10:08 AM
martin_metal_88's Avatar
I would not recomend this PSU to run your system if you want to overclock. Get a TX750 or anything like that they are cheap on price. Can be bought for less then 100$ sometime. But well, when Zero will see this thread he will give you the real hour. He know much more then me about PSU.
Old June 11, 2010, 11:20 AM
meh, he wont be pulling more than 300 watts stock i think, maybe 350? im sure ripple and such will get a tad unconfortable if it goes to the max 12 wattage written there.
Old June 11, 2010, 11:24 AM
i tried it on my older rig
Q9550 C1 clocked 3.6
gigabyte EP45
9600 GT clocked
i run prime95 and FurMark 4 hours and the power works smoothly and quiet
Old June 12, 2010, 01:38 AM
CroSsFiRe2009's Avatar
Should be fine for your needs. If you do upgrade your computer in the future, consider getting a better brand like Corsair, Seasonic, XFX, Silverstone, etc
Old June 16, 2010, 01:09 AM
it power my rig Ok but the fan was very loud
looks iam going for upgrade
Old June 16, 2010, 08:30 AM
I would recommend an upgrade. That PSU is a low-end FSP unit and I would not use it for a higher-end system. Take a look at the Antec NEO ECO series, the Seasonic S12II series, and Corsair's PSUs.
Old June 16, 2010, 08:37 AM
Soultribunal's Avatar
A Silverstone Strider Plus 750W would be perfect and at around $100 its awesome bang for your buck PSU unit. Very solid performance.
ST
www.realhardwarereviews.com
Old June 16, 2010, 09:05 AM
ST
A 750W PSU would be a complete waste for a system like this.
Old June 16, 2010, 09:45 AM
You perhaps Zero need to stop thinking on things as they stand and rather leave some room for upgrades in both GPU's and other items.
Unless extremely restricted in budget it is best have have your PSU firmly on your upgrade path already rather than it being a part of it.
My thoughts at least,
ST
Power supply for this system rfielder New Builds 25 January 12, 2010 09:32 PM
System Power Requirements for Radeon 5870 RBA Power Supplies 1 September 23, 2009 05:41 PM
Teaming Power Supplies for Single System CroSsFiRe2009 Power Supplies 12 July 4, 2009 05:54 PM
NVIDIA system sentintel reporting insufficient power? Mibs Video Cards 4 March 14, 2008 04:16 AM
PC Perspective reviews 1000W BFG Tech PC System power supply Supergrover Reviews & Articles from the Web 0 February 22, 2007 09:40 PM
