Old June 16, 2010, 09:49 AM
Originally Posted by Soultribunal View Post
You perhaps Zero need to stop thinking on things as they stand and rather leave some room for upgrades in both GPU's and other items.
Unless extremely restricted in budget it is best have have your PSU firmly on your upgrade path already rather than it being a part of it.
My thoughts at least,
ST
Unless you have definite plans to upgrade to a specific set of components that will require more power (which I have only seen a handful of times out of hundreds if not thousands of PC builds), it is best to purchase a PSU that is sufficient for your current needs, also keeping in mind that a PSU powerful enough to run a single card in this generation will also be enough to run a single card from the next generation. People should not be asked to spend more money than they need to since there is very little chance that it will actually benefit them in the future.
My thoughts at least.
Old June 16, 2010, 09:55 AM
stoanee's Avatar
ST
I agree with Soul, I think the PSU is one of the foundations of the system that can be moved around from build to build. Rarely does one (thinking of most posters here) downgrade their power requirements as time goes on. If you have even the smallest inkling that you will upgrade in the future then you should shop the deals, price matches etc and buy the biggest and best PSU your budget will allow. I would not hesitate to get a good 750 watt unit.
heatware
Old June 16, 2010, 04:38 PM
while i say spend 25 more now than 100 next year, if the gap is too big just stick with what yiu can get
Power supply for this system rfielder New Builds 25 January 12, 2010 09:32 PM
System Power Requirements for Radeon 5870 RBA Power Supplies 1 September 23, 2009 05:41 PM
Teaming Power Supplies for Single System CroSsFiRe2009 Power Supplies 12 July 4, 2009 05:54 PM
NVIDIA system sentintel reporting insufficient power? Mibs Video Cards 4 March 14, 2008 04:16 AM
PC Perspective reviews 1000W BFG Tech PC System power supply Supergrover Reviews & Articles from the Web 0 February 22, 2007 09:40 PM
