Old November 17, 2007, 01:31 PM
Babrbarossa's Avatar
I like my antec- don't find it loud, and take great comfort in knowing my voltages are right and there'd minimal ripple- especially since switching from the OCZ- I'm not sure what causes ripple, but I have a CM extreme power 550W here that weighs about twice as much as the OCZ and if PSUs are anything like amplifier/receivers, then light weight means distortion
EDit- to clarify, I was referring to the older OCZ GameXStream- not the newer PCP&C ones
Old November 17, 2007, 02:10 PM
Shadowmeph's Avatar
Originally Posted by SKYMTL View Post
I'm going to go out on a limb here.
Gigabyte Odin Pro 800W. It is one of the most overlooked PSUs out there right now even though it is a great performer with a very good price
what about the cable length on this PSU? it is a little pricey but
Old November 17, 2007, 05:27 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
I actually have the higher-end 800W GT version here to review. Let me unbox it and I will tell you tomorrow.
Old November 17, 2007, 05:38 PM
Shadowmeph's Avatar
Cool Thanks :)
Old November 17, 2007, 07:06 PM
magictorch's Avatar
Default perhaps this one too?
Silencer 750 Quad~$188
New Silencer® 750 Quad Power Supply
Enaberif recommended this one earlier in the post. Ive been thinking about getting one to give lots of headroom for ocing a quad and a GTX and later cards. Should fit your needs too.
Old November 20, 2007, 11:03 PM
You can find the PC P&C 750 onsale @ ncix for 159 fairly often.
Old November 22, 2007, 08:05 PM
dukelod's Avatar
I have this psu aswell, it's a work horse. I have my E6850 oc@3.4 and my evga 8800gtx at 645\1511\1036x2 very happy with.
Intel Core i7 930
Thermalright Ultra 120 Extreme Black Ultra Kaze 3000rpm
EVGA X58 3Way SLI A1
Corsair XMs3 6GB DDR3 1600
Windows 7 Ultimate 64bit
Antec Truepower Quattro 1200 OC Version
XFX GTX295
XFX GTX295
Coolermaster HAF 932
Logitech G15 Keyboard
Logitech G5 Mouse
X-Fi XtemeGamer
