Old June 2, 2010, 06:32 PM
MobiusD's Avatar
Question More than one PSU?
Ok so everyone has one PSU right? Why not run 2 PSU's? have one for the mainboard and peripherals, and second strictly for video, can't you just plug it in the wall and only connect the PSU to the cards alone?
Im thinking about trying it but dont want to melt anything, plus im too lazy to do the math...
I wonder, will it work???
think... raid for PSU's lol
Old June 2, 2010, 06:36 PM
It's been done and it works, it's annoying to rig both PSUs to start at the same time though.
Only needed for extreme setups though.
gingerbee's Avatar
yes you can do it but why the only time i have seen it done is when there doing 3oh6 kinda stuff you know a 6 ghz oc with 6 5970 ha ha. i wouldn't bother
Old June 2, 2010, 06:40 PM
MobiusD's Avatar
Just thought of it cuz i was shoppingfor a psu and noticed there isnt many on the market that have more than 4 pcie 6+2 pins or 8 pin pci connections, an yo cant split one connection, so how am i to supply 4 5850's with 180 watts each? any ideas?
Old June 2, 2010, 06:59 PM
Arinoth's Avatar
You need to look at 1000W or higher power supplies for that and they typically have all the connections you need as they have the power for it.
Here I am: here I remain
Old June 2, 2010, 07:04 PM
MobiusD's Avatar
I would love to see one with more than 4 pcie 8 pin or 6 pin connectors
not done searching for one but no luck so far, looking for 8 x 6 pin pcie 75 watt connections or 6x8 pin
Old June 2, 2010, 07:11 PM
gingerbee's Avatar
think 1000 or 1200 watts and use a molex+ pci-e adapter for the last card if it only has 6 pci-e. just a thought
Old June 2, 2010, 07:13 PM
sure. connect green and black wires with a solid wire, cover it up properly and use the on off button to turn it on of orr. so if it goes to video cards only, turn it on before mains
ALWAYS have a consumer on the psu, at least 50 watts so a pair of whatever cards will be ok.
Old June 2, 2010, 07:14 PM
MobiusD's Avatar
Thought of that, sounds like ill be sticking with that too, but I would love to try 2 PSU's, 2 modular 600 watt should do the trick as long as they have atleast 4x6 pin connectors each, shouldnt be too bad to setup, just need some solder and some cable ties
OR.... I could run a 750 and a 500 maybe
EDIT: my mainboard has a pci-e auxilliary power molex connection inbetween the obgpu and the pci-e x16 slots, still waiting to hear back from biostar to see what its rated for, I doubt it will help with any of the cards at all, im sure its only there fo the obgpu
Old June 2, 2010, 07:20 PM
SugarJ's Avatar
What you need is one of these adapters: Lian Li Dual Power Supply Adapter Cable - FrozenCPU.com No soldering required, doesn't screw up your existing PSU's.
Silverstone actually ships them with their big Temjin cases that have room for dual PSU's in the bottom.
Edit: That one's out of stock. This one isn't. Dual PSU 24-Pin Adapter Cable Products Model: ULT40011 [DualPSUAdapter] : Performance-PCs.com, ... sleeve it and they will come
And don't double post please (reply to yourself). Use the Edit button and add your new comments.
New PSU? headsh0t Power Supplies 7 November 21, 2009 01:48 PM
[WTB] Dual (same) 700W+ psu, or 1200W+ psu 3.0charlie Buy/Sell & Trade 12 October 7, 2009 07:07 AM
help with psu hohohee Power Supplies 9 July 24, 2009 09:46 AM
need PSU suggestions, current PSU isnt cutting it Rains Power Supplies 13 December 11, 2007 08:53 AM
PSU Help BALISTX Power Supplies 2 May 16, 2007 08:06 PM
