  #31 (permalink)
Old June 7, 2010, 08:48 PM
MobiusD's Avatar
lol knowledge, well, anyways, I did it, running 2 ultra 650's and yet to have any serious issues, had to go through a few things with the Biostar techs through e-mail to figure out the post errors that came up from the load differences between the psu's, easy fix, just had to even out the loads with a bunch of old case fans i had kicking around lol, lame but it worked, system runs mint once it does choose to boot.
So yeah if i can find a regulator of some sort online that would go between the atx crossover it should work like an OEM setup np
pictures coming
  #32 (permalink)
Old June 7, 2010, 09:01 PM
Do you even have the slightest idea of what you're talking about? You can't use a "regulator" between the PSUs. That would be completely useless if it's even possible.
  #33 (permalink)
Old June 7, 2010, 09:16 PM
MobiusD's Avatar
nope no idea at all :) pictures coming
  #34 (permalink)
Old June 11, 2010, 12:22 AM
Liu Kang's Avatar
Is there a reason we continue to entertain this retard?
LK
WORK KANG: Silverstone SG03 | EVGA x58 Micro w/ 920 @ 4.2Ghz | Sapphire 5970 | 12GB Dominator DDR3-2000 | 240GB Revodrive X2 | SilverStone ST650F
MINI KANG: BitFenix Prodigy | Asus P8Z77i Deluxe mITX w/ 2600K @ 4.5Ghz | EVGA GTX 680 2GB | 8GB Vengeance DDR3-1866 | 2x Intel 160GB SSD | Corsair AX650
KANGZILLA: Custom MM Ascension | SR-2 | 2x X5650 | 2x SilverStone ST1000F | 2x Intel 160GB SSD | 15x 120mm rads | Under construction...
New PSU? headsh0t Power Supplies 7 November 21, 2009 12:48 PM
[WTB] Dual (same) 700W+ psu, or 1200W+ psu 3.0charlie Buy/Sell & Trade 12 October 7, 2009 07:07 AM
help with psu hohohee Power Supplies 9 July 24, 2009 09:46 AM
need PSU suggestions, current PSU isnt cutting it Rains Power Supplies 13 December 11, 2007 07:53 AM
PSU Help BALISTX Power Supplies 2 May 16, 2007 08:06 PM
