Old June 2, 2010, 10:35 AM
Default Need Budget PSU
I've got an old computer that is still running strong for over 5 years 24h/24;
Motherboard: Asus P5ld2
CPU: P4 3.2ghz
RAM: 4gb DDR2 533mhz
6 HDD, 300GB to 1TB
GPU: Asus GeForce 9600GSO (bought like 6-8 month ago)
PSU: 420W Thermaltake
However, I think the psu is about to die... When the computer is idle/load,the psu does the most noise out of my thermaltake viking. I experienced slowdown in video and game when playing for long time. Is the psu working too hard? Is the videocard not getting enough juice?
What would you recommand to replace it ? Is it possible to get one arround 50$?
Old June 2, 2010, 10:51 AM
try swapping out first. besides noise(fan?) any smells, smoke? wel that would be the last you see.
those tt's are not half bad if not pushed beyong a couple hundred watts on the 12v.
Old June 2, 2010, 10:55 AM
martin_metal_88's Avatar
Look on the board if there is no bursted caps. But I won't be surprised about the PSU to die. If you are looking for good budget one these are pretty sweet
NCIX.com - Buy Sparkle Power SPI ATX-400PN 400W ATX12V 20/24PIN Power Supply W/ 120MM Fan P4 AMD Ready OEM - ATX-400-PN-B In Canada..
NCIX.com - Buy Corsair CMPSU-400CX 400CX 400W ATX 12V 30A Power Supply Active PFC 120MM Fan - CMPSU-400CX In Canada.
NCIX.com - Buy Silverstone Strider Essential ST50F-ES 500W Power Supply ATX 24PIN 120MM Fan 34A 80+ Black - ST50F-ES In Canada.
NCIX.com - Buy Antec Basiq BP500U 500W 24PIN ATX 12V Power Supply Active PFC - BP500U In Canada.
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Old June 2, 2010, 11:30 AM
big thumbs up for the sparkle, have some in builds with 8800gt's and more. again, dont push the 12v rail too much and you will be fine.
btw, 45 is a horrible price for it. ive picked up some a long while ago for under 30 bucks.
Old June 2, 2010, 11:31 AM
There is no smells or smoke, and i dont have a replacement to swap it...Its just that i dont remember it to be that noisie. When i stop the psu fan manually the case is near silent ! Is the psu running too hot so the fan keep spinning at high rpm?
How long a psu is supposed to last?I dont know much about effiency but could it be that after 5years its not as solid?
Thanks for the links, i will consider them. If you see any cheaper tell me:)
I dont want to put to much money on this system.
Edit: Alright i will check out sweet deal on these psu. Best direct has it for 38$ it would be awesome with free shipping thought...
Old June 2, 2010, 11:38 AM
rapmaster's Avatar
Sparkle Power SPI ATX-400PN 400W ATX12V 20/24PIN Power Supply W/ 120MM Fan P4 AMD Ready OEM - DirectCanada
Sparkle at a lower price.
Quando omni flunkus moritati
Old June 2, 2010, 11:52 AM
I see that the Corsair CMPSU-400CX 400CX 400W ATX 12V 30A Power Supply Active PFC 120MM Fan can go as low as 42$ at canadacomputer. However neither pricebat or pricecanada is up to date with price on this component. I just missed a deal at ncix on it 20$ less till june 1... Does it worth to wait a deal again on the corsair?
Old June 2, 2010, 12:10 PM
steers's Avatar
The 400CX is a pretty solid unit for the money. $40 is a great price for a basic, no-frills PSU in my opinion, but I guess it depends on your budget.
Balthasar - Loop: EK Multi 150 > MCP655 w/X-Top2 > Feser X-Changer 360 w/3x Panaflo 68cfm (push) > Heatkiller 3.0 > EK-FC275 > EK-FB Classified
Caspar - 2x Xeon E5504 | SuperMicro X8DAi | 12GB DDR3 | Radeon HD4850 | CM ATCS840
Melchior - Rev. A MacBook Pro | 2.0GHz Core Duo | 2GB DDR2 | Radeon X1600
Bob - Core i3 530 | Gigabyte H55N-USB3 | 4GB DDR3 | Corsair H50 w/ TFC Triebwerk | Silverstone SG06
Old June 2, 2010, 12:16 PM
My budget is arround 50$ and i wish shipping included.
and what about theses at ~30$+shipping?
Coolermaster Elite Power 400W ATX Power Supply 12V V2.3 20/24PIN 120MM Fan
or OCZ StealthXStream OCZ500SXS 500W ATX12V 24PIN Active PFC ATX Power Supply 120MM Fan Black
or Thermaltake TR2 430W Power Supply 20/24PIN ATX12V Dual 80MM Fans
or Rosewill RD400-2-DB 400W ATX V2.2 Power Supply = many good feedbacks?
If the corsair really better than i will wait when it get on sale!
Old June 2, 2010, 12:40 PM
ocz out of those. look up 12v and dont go near the limit :)
Budget i5 MOBO/PSU/HDD For Content Creation backpack New Builds 24 December 13, 2009 05:27 PM
PSU for budget build somecanadianguy Power Supplies 36 October 29, 2009 05:30 PM
Advice Needed: Best Budget PSU? cb2222 Power Supplies 7 August 28, 2009 07:04 PM
low budget psu CTA Power Supplies 8 March 28, 2009 03:30 AM
