  #21 (permalink)
Old June 17, 2010, 06:22 AM
Soultribunal's Avatar
Originally Posted by Zero82z View Post
The only PSU mentioned so far in this thread worth using is the CX400. All the other ones are pretty poor. The CX400 is pretty cheap to begin with, so even if you have to spend a few extra bucks to get one, it's worth it so you can have a decent PSU.
The only lower-wattage BFG PSUs left on the market are the bad ones.
Noted, I always thought BFG had actually improved in this department since the Guy from Ultra left to work for BFG's PSU Dept. Interesting to say the least.
ST
www.realhardwarereviews.com
  #22 (permalink)
Old June 17, 2010, 08:09 AM
ST
They did improve in that department. Then all the good lower-wattage units they introduced went EOL, and the only ones left are the older models that are not very good.
  #23 (permalink)
Old June 17, 2010, 06:29 PM
CroSsFiRe2009's Avatar
Yep, I can confirm what zero is saying. I was doing some research for my budget build before and it seems every single decent low end psu bfg ever made is oel and gone. The corsair 400W CX is pretty much the best budget psu out there but I'd also consider the OCZ 500W Stealthxstream if you can get it for $20 if saving money, even $10, is the ultimate goal. If you need a bit more juice I think there's a 500W Seasonic on newegg for a decent price.
I should also mention that if you need 'more quietness' just do a fan swap. on the psu
  #24 (permalink)
Old June 18, 2010, 03:22 AM
with mini itx boards poping out, what very good AND compact psus can one find tehse days, to run say 400-500 watts of stuff? of course you wont fit a bigger video card in there, but still
  #25 (permalink)
Old June 18, 2010, 09:25 AM
Seasonic, Antec, and Corsair have PSUs that would be sufficient for decent mini-ITX machines. Most ITX cases either come with small PSUs already or have mounting space for an ATX or mATX PSU anyway.
Budget i5 MOBO/PSU/HDD For Content Creation backpack New Builds 24 December 13, 2009 06:27 PM
PSU for budget build somecanadianguy Power Supplies 36 October 29, 2009 05:30 PM
Advice Needed: Best Budget PSU? cb2222 Power Supplies 7 August 28, 2009 07:04 PM
low budget psu CTA Power Supplies 8 March 28, 2009 03:30 AM
