Old May 19, 2010, 11:50 AM
Default PSU : Tester
I worked in a computer shop a while back and now do my own running around on the side of my full time job. I'm curious if anyone knows where I can get a good but not huge expensive PSU tester.
The one's I'm use to using are plug the power cable into power supply plug the seperate (20/24 pin) in one side and if it all lights up green good if not, get new psu in most cases) and ofcourse it can test the 8 pin and 4 pin connectors as well. Not sure if I ever saw one that tested the 6 pin connectors (PCI-E).
Thanks in advance or if anyone has a used one for sale let me know asap as well.
Thanks!
Comp1 (Mine) : ASUS Sabertooth, i7 2700K, 8GB 2133 GSkill, XFX 7970 DD, OCZ Vertex3 240GB, OCZ Vertex3 480GB, 600GB VelociRaptor, Corsair 1000HX, Cool Master Cosmos 2
Comp2 (Wife's) : Intel DP67BG, i7 2600K, 8GB Corsair Vengeance 1866, 1TB HD, 2TB HD, Sapphire 7950 OC, Corsair 950W, HAF 922
Comp3 (Kids) : ASUS P8P67 Pro, i7 2700K, 8GB 1866 GSkill, Sapphire 7970, Crucial M4 120GB, OCZ Vertex3 240GB,1TB WD Black, Antec 850W, Antec 1200
Old May 19, 2010, 12:06 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
So what exactly are you looking to test?
Old May 19, 2010, 12:07 PM
N.V.M.'s Avatar
since this is the "i love NCIX" site, go to NCIX and search "psu test". there's a couple of them there.
Old May 19, 2010, 12:11 PM
gingerbee's Avatar
Newegg.ca - psu tester
NCIX.com - Canada's Premier Computer Store - Great Technology, Service and Selection.
shopping at ncix has nothing to do with love it's pure business or should i say pricematching
Old May 19, 2010, 12:15 PM
There are a few PSU's that I am working on for myself and for other people that I believe might be slowly dying and not giving enough power (random reboots or shutdowns and a few that spin but just dont seem to be enough juice, tested the RAM etc and it doesnt seem faulty so inless its the mobo itself (didnt see any popped capicters (sp?), then I believe it to be the PSU!
This tool should quickly test the PSU for me :)
Old May 19, 2010, 12:18 PM
sswilson's Avatar
Keep in mind that most PSU testers won't give you much of an indication other than non-load voltages.
Old May 19, 2010, 12:21 PM
gingerbee's Avatar
the digital ones give you more info then just a light up that means it works ok
Old May 19, 2010, 12:36 PM
N.V.M.'s Avatar
there's a store down the road from one of the NCIX locations that has a Thermaltake tester for about $16. looks like its designed to test P4 connector,Molex, sata,20-24 pin...etc.
here: ATIC Computers - Accessories / Thermaltake - A2358 - Dr. Power PSU Tester
however, when i test a customers PSU, i use a spare PSU that i know is working. as mentioned, when a line is under load, nothing beats a real PSU to test it.
Old May 19, 2010, 01:51 PM
i trust mine, but load testing is required.
Old May 19, 2010, 03:28 PM
Perineum's Avatar
I have one of those voltage testers.... you really can't verify a PSU 100% until its under load, so I really don't know about the effectiveness of these testers.
I mean... if the PSU is definitely (HA! spell checker caught that one again..) dead then the tester will tell you, but it won't help much to tell you it's "mostly" dead.
[WTB] Dual (same) 700W+ psu, or 1200W+ psu 3.0charlie Buy/Sell & Trade 12 October 7, 2009 07:07 AM
Artificial heatsink tester krazyups Air Cooling 7 August 1, 2009 06:22 AM
help with psu hohohee Power Supplies 9 July 24, 2009 09:46 AM
New "tester build" Wall86 New Builds 0 October 10, 2008 01:47 PM
need PSU suggestions, current PSU isnt cutting it Rains Power Supplies 13 December 11, 2007 07:53 AM
