Old May 9, 2010, 04:36 AM
Soultribunal's Avatar
NCIX.com - Buy Silverstone Strider 750 Plus 750W Modular Power Supply ATX 24PIN 135mm Fan 60A 80+ Silver Black - ST75F-P In Canada.
Another good Option I think. This one has been quite the solid PSU For me.
ST
www.realhardwarereviews.com
Old May 9, 2010, 06:10 AM
the ocz are ok, not the best, not bad. ok.
i prefer corsair, but those are more expensive. look up a used unit if you can
Old May 9, 2010, 09:44 AM
Fox's Avatar
Fox Fox is offline
Thanks for the responses, I think I'll probably go for the M12D and just keep my crappy BFG 650W and maybe just replace the 80mm fan.
Old May 9, 2010, 09:50 AM
gingerbee's Avatar
I swear by seasonic
NCIX.com - Buy Seasonic M12D 850W EPS12V 20/24PIN ATX Modular Power Supply Active PFC 80PLUS 8PIN PCI-E 120MM Fan - M12D-850W In Canada.
NCIX.com - Buy Seasonic M12II 520W EPS12V 20/24PIN ATX PFC 80+ Bronze Modular Connectors 6PIN PCI-W 120MM Fan - M12II 520 In Canada.
Old May 9, 2010, 02:26 PM
EaGle1337's Avatar
yup you can't go wrong with Seasonic. the silverstone Strider plus are amazing psus as well, but it happens to cost a bit more then the M12D
Old May 9, 2010, 02:59 PM
geokilla's Avatar
All this hate on OCZ. I got a OCZ StealthXStream 500W powering my sister's rig and it's excellent. Oh I picked it up for around $30 AR almost a year ago. My system is powered by a OCZ GameXStream 600W and it's doing great as well.
Old May 9, 2010, 03:23 PM
Bond007's Avatar
Its not that they don't work, its just that they aren't in the same league as others PSUs being mentioned.
Old May 9, 2010, 07:21 PM
When you're running a 150-200W load, even a shitty PSU will generally not have any problems. Make no mistake, both of those OCZ PSUs are still low-quality units, and are not trustworthy for any load above 400W or so.
Looking for some advice.. Souljah New Builds 8 March 1, 2010 11:59 AM
Need some advice donkon Water Cooling 87 May 21, 2009 02:47 PM
Hi I need your advice/help blogz101 New Builds 4 July 7, 2008 08:20 PM
In need of advice doup93 Video Cards 6 March 17, 2008 05:40 PM
need advice Rapid-X CPU's and Motherboards 7 January 30, 2008 04:15 PM
