Old November 7, 2007, 08:29 PM
Cptn Vortex's Avatar
Default How much power would you recommend?
I will be getting a second 8800GTX now, so I will need to change my PSU, sadly, as I just got it. Here's what we're powering:
EVGA 680i board, 4GB RAM, Xeon X3210 Quad at 3.2GHZ, two 8800GTX's SLI, Swiftech H20-220 Apex watercooling kit, 4 harddrives, a DVD drive, and numberour fans. I am eyeing the Silverstone Stryder 750W modular, it looks to be excellent. Is this more than enough power? Recommendations? I already tried the Antec TPQ 850W and it left a bad taste in my mouth, when it conflicted with my GTX.
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
Old November 7, 2007, 08:42 PM
3.0charlie's Avatar
Exclamation
High-end board, oc'ed Quad, 4 sticks, 4 HDDs, water-cooling, fans, fans, fans... I don't know much about PSUs, but personally I would it the 1KW mark with a set-up like yours.
edit: Ha! I did the calcs with the PSU calculator, using the info you gave (minus the CPU volts, which I guesstimated at 1.5V) and the result was 906W, with 90% load factor.
Old November 7, 2007, 09:08 PM
Amon's Avatar
Only the superbly constructed Enermax Galaxy 1000 comes to mind in that region of power necessities.
Old November 7, 2007, 11:43 PM
Corsair. HX620 or TX750.
Both can easily handle SLI GTX and are 80% + efficient... and quiet.
Old November 8, 2007, 03:02 AM
CPU Volts are actually at 1.25.....it overclocks like a beast.... I know the 620 I have "should" be fine, but it's too close for comfort. Also, I want 4 PCIe cables coming out of the powersupply, don't want to have to use the molex to PCIe adapters, cause they look ugly.
The Vortex H20
MSI Z77A-GD65
Benq W500 Pojector.
Watercooling:
Old November 8, 2007, 06:57 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
1000W is pure overkill. I calculate that you will not be drawing over 650W at full load when gaming. IMO, the Corsair TX750 should be near the top of your list along with the DA850 and OP850. There is also the option of some of the new Zalman power supplies. Unfortunately, here in Canada I would resommend ANYTHING BUT an Enermax PSU.
Old December 10, 2007, 01:50 PM
i have a question too?
with an asus p5kc
intel e6750 (no oc, but planing to oc it to 3ghz)
2ghz crucial ballistix tracer 800 mhz
evga 8800gt superclocked
1 seagate barracuda 250gig
1 seagate barracuda 500gig
thermalright ultra 120 heatsink with antec tricool 120mm fan
thermaltake duorb
and the nzxt nemesis elite gaming case
how much power do i need?
i have an antec earthwatt 500w
p.s. i don't have the 8800gt, crucial ballistix and the two heatsink but ill buy them soon.
i have an evga 7900gs oc and 2gig corsair xtwin 667mhz
Old December 10, 2007, 02:35 PM
The corsair seems like a good choice to me too so +1 there.
If I'm not mistaken the corsair is made by Seasonic whom make excellent psu's.
which CPU do you recommend? vblanche CPU's and Motherboards 23 September 15, 2007 09:34 AM
Please Recommend a Case for my Needs SKYMTL Cases 21 August 29, 2007 09:41 AM
Recommend me a good 5.1 Surround sounds Speaker set! Patriote Audio 23 July 28, 2007 03:57 PM
Recommend a DX10 Game Babrbarossa Gaming 16 July 2, 2007 07:10 PM
