-   -   Extending PSU Cables? (http://www.hardwarecanucks.com/forum/power-supplies/31472-extending-psu-cables.html)
ilya April 27, 2010 07:28 PM
The 12V CPU connector on my SS X750 isn't long enough to reach behind the mobo tray and get to the connector in the corner. So it hangs over my motherboard and it really takes away from getting to pristine cable management.
So I was wondering, could I cut the cables in the middle and solder extension wires of same thickness without affecting the electrical integrity of the wire?
Or should I extend the wires from one end of the connectors?
I don't wanna buy one of those NZXT extensions for a few reasons:
I don't have much room behind my mobo tray.
I plan on sleeving my cables white, don't want to have to bleach the extension cables and re-sleeve it white. (NZXT cheats and uses average black sleeving on black wires)
I don't think I should have much problems soldering the wires, except for the uneven bumps I'll find after sleeving, but I was wondering if anybody has done this before or knows anything about this.
Zero82z April 27, 2010 07:34 PM
You can do that, but I suggest that you heatshrink the solder joints very well to prevent them from being overstressed and breaking.
_dangtx_ April 27, 2010 07:39 PM
id get the cable, but i commend you for the jobbe to come. drop a few piccies if you will :)
last time i did it i messed up one wire(years ago) the result was rather nice(smokey)
boggtrotter59 April 27, 2010 07:45 PM
I have done this several times without issue to get cables to reach in large cases... just make sure extension wires are the same gauge and the joints are well insulated... I used regular electrical tape and just tucked the spliced joints behind the mobo tray where you can't see them...
ZZLEE April 27, 2010 07:50 PM
Pm Amuseme
"Amuseme" recently used an extension on his " Last Client build" thread he may sugest a sorce.:thumb:
Digikid April 27, 2010 08:52 PM
Get the extension kit. I will never recommend fooling around with a power supplies wiring. Too dangerous.
Zero82z April 27, 2010 08:56 PM
It's really not dangerous at all if you do it properly, which isn't hard.
BrainEater April 28, 2010 07:57 AM
Time and patience.
Here's a six foot one I made :
http://braineater.kicks-ass.tv/miscshite/tt2_455.jpg
:thumb:
ilya April 28, 2010 03:41 PM
So I got the Mod Smart sleeving kit at NCIX and when I opened it up just now, I realized I goofed and the kit is no good for the in connector uni cable sleeving I was planning on doing. It only comes with 10' of 1/8" sleeving but it comes with 25' of 1/4" sleeving. So I'm hoping I can jam the 1/4 into the 24 pin connector. Caliper says the so called 1/4" is actually 3/16", so I might be in luck.
