Old October 30, 2007, 10:55 PM
Default Sparkle Power SPI ATX-400PN 400W ATX12V
8800 GT needs 26a on the 12v or so it says.
Would this power supply -> http://www.ncix.com/search/?q=17076&...ice=Max.+Price
Running ONLY the video card be enough?
Yes or no.
Old October 30, 2007, 11:14 PM
Cptn Vortex's Avatar
So you mean only the videocard, as in using this PSU in conjunction with another?
The Vortex H20
EVGA SR-2 Classified
2 x Xeon L5639 Hexcore CPUs, 3.2GHZ
EVGA GTX 580 - 940/2115
24GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 90GB Corsair Force SSD RAID0
Sharp 32" Aquos 1080p
Benq W500 Pojector.
Watercooling:
2 x EK Supreme HF, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, XSPC GTX 580 FC block, EK Coolstream XT 220 RAD Gelid Wings Push - CM R4s Pull.
Old October 30, 2007, 11:15 PM
Correct. I'll use my 850 until I can get a replacement or something sorted out and use the sparkle for just the video card.
A website states 450w with 30a but thats with an entire system so I should assume only used with the video card it should be fine right?
4pin ATX12v and 8pin EPS connector magictorch Power Supplies 6 December 6, 2007 04:39 PM
Comment thread for Nexus 400W Power Supply SKYMTL Power Supplies 2 July 31, 2007 02:56 PM
8800 GTS 320: Sparkle vs eVGA vs BFG vs XFX BALISTX Video Cards 10 February 21, 2007 08:23 PM
