Old March 28, 2010, 07:55 AM
Delavan's Avatar
Default In case I buy a GTX480...
Hi!
I got a Antec TruePower Trio 650 for the rig in sig. I might get a GTX480, that would be my last GFX card for 2 or 3 years (that's why I think of going BIG).
The TP3 650 could possibly be fitted with adapters (2 molex to 8pin) to power this 480, but I might keep it for spare...might even use it in my daughter's rig (and give her my GTX260).
Anyway, there is quite a few 750W to 850W PSUs around.
I'll go thru SKYMTL's review of "9-way 850 w PSU roundup).
MOST have multiple 6+2 pins adapters....not sure if I like that. Are the genuine 8pin PCI-e connectors a lot better?
From the specs, a 6pin PCI-e can carry 75 watts/connector. A 8pin is 150Watts. These 6+2pins seem like 6pins with 2 extra grounds...can they carry the same 150watts?
A 750w could probably do the job just fine, but a 850w (especially PMed is not much more).
With a 850, I could possibly run my "possible" GTX480 and add my "backup" 8800GTS640mb SC as a PHYSX card....
On a more serious note, is it possible to run a 2nd card for PHYSx on a P5Q PRO (crossfire board) that reverts to 8x/8x if both PCI-E slots are populated? Could it cripple a new card like the GTX480???
I know it sounds crazy...I'm just preparing for the LONG haul....I put enough money in computers, so after this "possible" move, I'll start to save for other things...
i5 2500K @ 4.5GHz / NH-U12P / P8P67 DELUXE / 8GB Corsair Vengeance Arctic White 1.35V 1600 / 2 x N560GTX Ti Twin FROZR II OC in SLI (8823 3Dmarks11 P-score)/ Corsair Performance Pro 128GB SSD
Old March 28, 2010, 08:04 AM
jcmaz's Avatar
Those 6+2 pins are not adapters.... they perform just a well as the 8 pins ones...
-Plato
Old March 28, 2010, 10:23 AM
encorp's Avatar
Yeah they are not adapters, basically they are full connectors except two pins snap off at the end on the connector (but are still connected by the wire). It's a modular design I guess you could say, but they are just as safe as a full 8 pin.
DISCLAIMER: The views and opinions expressed in the immediately preceding post are those of encorp and do not reflect the views and/or opinions of family, friends, or anyone remotely associated with encorp unless explicitly stated. encorp does not make any warranty, express or implied, or assumes any liability or responsibility for the quality, factuality or use of information in the immediately preceding post.
Old March 28, 2010, 08:24 PM
Delavan's Avatar
Thanks for the replies!
I think I'll settle for a GTX470. Well I'll wait until the cards show up on the market in 2 weeks, to see if NCIX will stock some, see if they get more XFX HD5870s in...see how the prices are.
At least, with these cards, my PSU is fine...
Old March 29, 2010, 09:08 PM
encorp's Avatar
Well at least you have an idea what to do. I think I'll just throw my whole system out hahaah
Old March 29, 2010, 09:31 PM
Technically an 8-pin PCI-E connector is supposed to have one additional ground plus a +12V sense wire compared to the 6-pin, but most manufacturers substitute another ground for the +12V sense, which still works fine. There is no functional difference between a 6+2 connector and an 8-pin connector. They can all deliver the full 150W.
1) Yes, you can do that.
2) I don't think PCI-E bandwidth testing has been done yet with the 470 or 480 to determine whether an 8x PCI-E 2.0 slot would be a bottleneck. But just on a hunch, I would say that you probably wouldn't see any real difference.
Old March 30, 2010, 04:54 AM
Sushi Warrior's Avatar
Even a 4x slot only drops performance by 8% on a 480 ;)
You're half way through some post and you realize it's from some retard who types like he's got an array of dog dicks for fingers
Old March 31, 2010, 10:03 AM
techPowerUp :: GeForce GTX 480 PCI-Express Scaling Review :: Page 12 / 25
Theres's some scaling.
x4 965BE 3.7ghz / Tuniq Tower 120/ xfire HD6870s / 4x2GB G.skill/ S12D 850w/ Ga Ma 790X-UD4/WD640AALS Black x2, WD1TB FALS x1, Seagate 250GB x1/ BenQ 21.5" 1920x1080/ Win 7 64
Old April 2, 2010, 05:17 AM
Delavan's Avatar
Well,
This topic that i started takes a strange twist for me.
I canceled my GTX4** pre-order and got an XFX HD5870, pricematched it to $426. I'm in no need for a new PSU now.
If I'd really need PHYSX, I guess I could buy a new PSU for me, transfer my GTX260/existing PSU in my kids rig , take the 8800GTS 640mo out an use it in my rig for a Physx card.
Not too sure if it's worth it, a new PSU would cost me a good $120 for a 750watts Pricematched (Antec, Silverstone or Corsair, XFX) and I'd loose the $100 I'm getting by selling my GTX260 to a good clanmate of mine.
So, in my opinion, it's NOT worth it to spent $220 for PHYSX...don't you think?
Old April 2, 2010, 07:23 AM
was curious about how it handle the psu. theres a thread on another forum indicating issues with multiple rail units, altough it looked like april fools to me.
for physix you could use a 9800gt, i think its overkill for the good ole gtx260 to fulfill that lowly role lol
Cheapest place to buy microATX case RLP06 New Builds 1 March 27, 2010 03:33 PM
Never buy a Canada Comptuer case geokilla Cases 8 August 2, 2009 07:41 PM
What is the best place to buy window decals for my case? Gameplaywarrior Cases 6 July 29, 2009 10:01 PM
Any reason not to buy this case? Nodscene HTPC Systems & Software 19 April 23, 2009 09:00 AM
dose anyone know where can i buy a rig case? cmhyt Cases 7 July 5, 2008 01:47 PM
