Old March 17, 2010, 10:47 AM
Default computer and its electricity cost
Trying to figure out how much electricity my computer uses cause the bill was astronimical this month. Is there something that can record or monitor it for you?
Heres my setup
AMD 965 125w 3.4 overclocked to 3.8 1.4 volts
8 gb crucial ram *4 sticks total*
samsung spinpoint
750 w power supply
3 scythe 3000rpm fans
2 2000 rpm fans
ati 5850 be
msi 790fx
The thing is this isnt even running very long maybe 2-6 hours a night
Electricity bill went up by 60-70 dollars.
Old March 17, 2010, 11:17 AM
lowfat's Avatar
It will be using under $10 a month easy if you are only using it for a few hours a day.
1. Xeon ES 4c/8t * X79-UD3 * HD7970 * 16GB DDR3 * 64GB Crucial M4 * 80GB ioXtreme * 1000W Silverstone
2: 27" iMac * i5 750 * 80GB X25-M G2 * 4GB DDR3 *
3: 2600k * P8P67 Pro * GTX460 * 16GB DDR3 * 40GB X25-V * RR2314 * (2) Sans Digital TR8M-B * 46TB * 1050W Enermax
Old March 17, 2010, 11:45 AM
dragoonxx's Avatar
as far as something to plug in- a kill-a-watt meter, or something of that manner
increased cost is probably likely due to increased heating costs
Old March 17, 2010, 12:12 PM
im thinking maybe 350-400 watts for the rig? maybe less. if the psu is mighty inefficient(above certain loads ;) ) then it could explain it too.
as per above, get yourself a 10-20 dollar killawatt. youll put a power bar on everything and switch it off when not needed. my tv and dvd thing consume 20-25 watts doing nothing(turned off, plugged in still)
Old March 17, 2010, 12:14 PM
DK2 DK2 is offline
I’ve got;
GTX280, Q9550, Coolit Elite (80W ?), 4 HDD, about 7 fans and some lights etc,
it runs about 240W idle and 400+W gaming.
Its been awhile since I’ve even looked at the watt meter, so I’m guessing a bit.
5 hrs @ 400 = 2000whrs
19 hrs @ 240 = 4560 whrs
Total 6560whrs/day (6.56kwh
@0.06 /kwh that’s 0.40 per day, or $12 a month. (hmmm, about 13% of my bill)
Anyways I leave it on just because David Suzuki told me to Flick Off. Spite!
By your parts, it’ll be less than that even if you left it on 24/7 like I do.
Must be something else to be $60-70 over.
Did you switch to a new smart meter? Because thats about right then. LOL
Old March 17, 2010, 12:44 PM
thats what i figured maybe $10 max a month. Must be my heater or something else eating it up.
Old March 17, 2010, 12:45 PM
my 2nd question would that setup be able to ,on a ocz modxstream pro 700watt 80plus certified, run another xfx ati 5850 be?
Old March 17, 2010, 01:33 PM
Eldonko's Avatar
Hardware Canucks Reviewer
If you want to know for sure --> Blueplanet EM100 at Canadian Tire, $20 :)
Folding@home electricity use Perineum HardwareCanucks F@H Team 103 November 13, 2009 02:17 PM
Windows 7 cost shammancer O/S's, Drivers & General Software 10 October 23, 2009 06:53 PM
Want to save Electricity while Folding with your Videocard??? Follow these Steps! Dashock HardwareCanucks F@H Team 4 April 21, 2009 11:05 PM
260GTX 216 and electricity bill... xXxRithxXx Video Cards 10 April 11, 2009 10:45 AM
cost to run i7 920? somecanadianguy CPU's and Motherboards 10 April 2, 2009 10:49 PM
