-   -   Silverstone Strider Plus 850 review (http://www.hardwarecanucks.com/forum/power-supplies/29872-silverstone-strider-plus-850-review.html)
shasta65 March 14, 2010 04:00 PM
In regards to the Silverstone Strider 850 review, and the comment that the PCI cables had a "capacitor" attached to the end to "supposedly" reduce "ripple"and improve "volatge regulation".
The photo shows what appears to be a heat-shrinked tubular device on these cables. That makes it a ordinary ferrite choke (inductor) surrounding the conductors. This adds inductive reactance to the circuit. It's a simple line noise filter, (and a nice touch). See any HP laptop power supply for comparables.
Secondly, IMO the computer bad capacitor scandal is long gone. What I'd like to see in PSU reviews for filtering specs is:
1. Size in microfarads plus total primary and secondary values.
2. Temp rating.
3. Type of cap.
9. Manufacturer.
SKYMTL March 14, 2010 04:33 PM
They are filter capacitors. Not ferrite chokes like Tagan / Topower add to their units.
Photograph March 16, 2010 05:37 AM
I have a Strider Plus 850, good little PSU but I find that the fan is a little on the noisy side for my liking. I may swap it out for a Noctua 140mm at the end of it's warranty period.
shasta65 March 25, 2010 06:21 PM
Silverstone 1/2 replies...
I've also contacted Silverstone USA and Taiwan; (which declined to comment).
USA says: "It is a capacitor to reduce electrical whine/buzz associated with high performance graphics cardís dynamic loading changes."
So it *is a cap, and a line noise filter, but in this position is electrically impossible to affect 'ripple' or 'voltage regulation'.
