Old March 7, 2010, 08:11 PM
wonton1017's Avatar
Exclamation Am i pushing my power supply's limit?
Wondering i am pushing my PSU's limits.
My rig is the following:
Intel i7 860 @ 4.25ghz
Gigabyte P55-UD4P
Coolermaster V8 (replaced fan with yate loon for more cfm and lower dba)
G. Skill DDR3 1600mhz RAM 2x2GB @ 1.5v
eVGA GTX295 CO-OP FTW Overclocked
HAF922 w/ 3x 120mm and 2x 200mm LED
2x red led tubes (12in)
2x 640gb Caviar Black in RAID 0
Samsung DVDRW
ASUS Sound card
DLink wireless PCI adapter
Going to add: 1x 32-64gb SSD for Windows
Antec Truepower New 650w (Link: http://benchmarkreviews.com/index.ph...1&limitstart=1)
Old March 7, 2010, 08:24 PM
Nope.
Old March 7, 2010, 09:25 PM
wonton1017's Avatar
When will i need a new powersupply?
Old March 7, 2010, 10:27 PM
when adding another video card. which i doubt you need to do anytime soon with a 295
Old March 7, 2010, 11:34 PM
Whenever you put together a system that needs more power than your current one can provide.
Old March 8, 2010, 02:57 AM
wonton1017's Avatar
How much extra watts do i have? If that makes sense.
Old March 8, 2010, 08:13 AM
As a rough estimate, I'd say at least 250W.
Old March 8, 2010, 08:56 PM
Oversized Rooster's Avatar
Assuming the system to be at load, I'd say it would use up about 500W leaving you with 150W. No need to change the PSU yet.
Main: Intel 2600K @ 4.8GHz | Gigabyte P67A-UD7-B3 | 16GB Corsair DDR3-2000 | 2x120GB OCZ Vertex 2 in RAID0 | 7x2TB WD Caviar Black | 3WARE 9650SE | Antec 1200 | Seasonic M12D 850W | 1.5GB GTX 580 | 2x27" Asus VE278Q | Auzentech Prelude | Win7 Pro 64-bit
Office: Intel 655K @ 4.4GHz | Gigabyte P55A-UD3 | 8GB G.Skill DDR3-1600 | 2x40GB in RAID0 Corsair Force | 640GB WD Caviar Black | Antec NSK4482B | Corsair Builder 500W | 1GB Radeon HD 6450 | 2x25.5" Asus VW266H | Win7 Pro 64-bit
Old March 8, 2010, 09:05 PM
BobbyLou's Avatar
yah you should be good if you add another 295 id go for a 750w-850w
Old March 8, 2010, 09:37 PM
keep it within spec and you should be fine. only beef i have with some antec units is, even tough i love the quiet operation, the darn fan wont ever spin up to where it should even when under uber load. the result is that if you keep pushing the above and it doesnt ramp up enough, life expectancy will be shortened by a bit.
Really Pushing The 920 To Its Limit ! JORD4N CPU's and Motherboards 48 January 28, 2010 09:45 PM
[WTB] power supply 650+ power supply j-ronde Buy/Sell & Trade 1 March 31, 2009 10:45 AM
SLI and CrossFire Push Power Supplies to the Limit Gav Troubleshooting 3 February 12, 2007 04:09 PM
